Vin number scavenger hunt!!
I was thinking about something interesting. I saw that there is a 70 thru 73 registry,but mybe it would be interesting and helpful to start a short list on a sticky tread here,with last 6 digits,trim tag date and bodynumber of as many Camaros from 70 thru 81 as possible. Once we get about 1 car for each month of the years 70 thru 81 we can close it,and I will orginize the numbers and submit them as a list. It would be cool to keep a simple list so that people who are looking to weed out VIN and trim tag swapped cars can have a little referance. The cars wouldnt need to be anything special,and you could even comb Ebay or other internet sites and take info from cars that look credible. When done a list of 144 cars containing only the very short amount of info needed shouldnt take up very much space at all,and could probably be condensd into 1 or 2 poists on the tread. Then it could be sticked so we could be the go to guys for yet another piece of 2nd gen info.
So what do you all say?? |
sounds like a pretty good idea to me.. I'll play
+1. Should this be in the VIN and Trim Tag Forum though?
I Agree!
Moved.
trim tag date and body # were is that located on the tag ?? |
My 3 turds.
1973 base model camaro. VIN 108600 date 11D Body 018429 1974 type LT VIN 102504 Date 08c (thats August of 73) Body 0192229 1979 Base model VIN 561264 (La built car) Date 01c Body either 145529 So I went first. Look up your model year info the nasty z/28 home page for how to decode your trim tag. |
'74 Z28
VIN 221393 Norwood Date 06B Body 242235 |
1974 Type LT/Z28
VIN 245113 Norwood Date 08B (August 1974) Body 276105 |
'73 RS
VIN 105057 Norwood Date 11B Body 013373 |
These are all in my collection. Will try to add a few more each day.
1973 Type LT VIN 163683 (Norwood) Date 04C Body 110299 1975 RS VIN 557350 (Norwood) Date 01D Body 144240 1976 RS VIN 636832 (Norwood) Date 07C Body 291982 1977 RS VIN 534993 (LA) Date 11C Body 094816 1979 RS VIN 646701 (LA) Date 07E Body 305865 1979 Z28 VIN 505554 (Norwood) Date 09C Body 014122 1979 Z28 VIN 514695 (LA) Date 09D Body 049714 1979 Z28 VIN 527633 (Norwood) Date 11C Body 074047 1979 Z28 VIN 542650 (Norwood) Date 12C Body 099034 1979 Z28 VIN 579341 (LA) Date 02D Body 183276 1979 Z28 VIN 580808 (LA) Date 03A Body 185895 1979 Z28 VIN 594927 (LA) Date 04A Body 211211 1979 Z28 VIN 604832 (Norwood) Date 05D Body 210354 1979 Z28 VIN 609326 (Norwood) Date 06A Body 234896 1980 Z28 VIN 545960 (LA) Date 03A Body 095847 1981 Z28 VIN 131104 (Norwood) Date 05A Body 207054 1981 Z28 VIN 137922 (Norwood) Date 06D Body 217825 1981 Z28 VIN 157622 (LA) Date 05C Body 123255 |
I'm not so sure that is a good idea posting everything you need to create another car. Just the little bit of info posted so far is everything someone needs to build a car including new VIN and trim tags.
Just looking at this from another view. Rick H. |
lol^^
would love to see your collection in person one day. me= jealous:bowtie: |
1975 LT
VIN 515436 Norwood Date 10A Body 050851 |
The value of most cars is relatively low these days. Only a numbers matching car is really valuable to go through all the hoopla to duplicate the VIN/body tags. And if you buy one, you should do your homework. I could build a numbers matching 1970 Z28 clone and license it in Florida. No one would ever figure out it wasn't an original. It's not easy, but it can be done. Having VIN info doesn't help. Having body info doesn't help. There is info available that will allow you to clone a more expensive version of the 1970, for example. But if you go to the trouble to exactly duplicate the numbers on a clone, it should be worth more than a non-numbers matching car. This isn't rocket science...cause I know rocket science! :D |
| All times are GMT -4. The time now is 12:47:32 PM. |
