Old 07-02-2011, 06:33:59 PM   #766
Hoot
Got an oil leak from the Felpro/National front timing seal. Found out this is a known issue. Ordered a seal and sleeve from Carquest/napa. It will be here wensday since holiday.
Anyway... Today I reset all the valves the old fashioned way. With it running. Swore I could hear one ticking slightly since the gear drive was gone.
I cleaned the car real good too. Scrubbed wheels and all. Cleaned enging bay a bit too. It really wasnt too bad except the screws that hold the caps on the wheels.
Then I got a wild hair and decided it was time to take out the 4 6x9's that were destroyed by the sun (dont buy cheap stuff). Went and bought a new pair of Memphis Car Audio speakers. I also had an old 10" sub sitting around sooo. Went and got a piece of mdf, 2' of black carpet and redid the back deck. No more 4 6x9. Now its 2 6x9 and a 10". About died from the heat, was in the high 90's today. Inside a black car out in the sun isnt the place to be lol.
Still need to clean the windows but I was tooo hot and toooo tired to care right now.
Heard something about a bike stunt and car/truck show tomorrow in town. So Im going to try and go to my first show with my Firechicken.
The fruits of my sweaty labor today
OH BTW who wants to come be my gardener for a couple weeks. Ill supply all the beer you can drink
1973 Firechicken "Troy Built"
Project thread http://www.nastyz28.com/forum/showthread.php?t=130791
Member of the Dark Side
Nothing to it, but to Duit !
Hoot is offline   Reply With Quote
Old 07-03-2011, 06:54:00 AM   #767
Teamchevy
Teamchevy's Avatar
Looking real nice Hoot! Good luck at the show!
Dave
1976 LT - 350 4 spd
Project Progress Link: http://www.nastyz28.com/forum/showthread.php?t=134389
Garage Build Link: http://www.nastyz28.com/forum/showthread.php?t=196017
"BBFL"
Teamchevy is offline   Reply With Quote
Old 08-02-2011, 02:20:19 PM   #768
BusDriver
Nice... It's fun, yes?
I need to update or start a new thread on my bird. I've been working and not reporting. I know, bad bad!
'03 Yellow S-10 4.3L - "The Bus"
'78 Firebird - Progress: http://www.nastyz28.com/forum/showthread.php?t=142245
BusDriver is offline   Reply With Quote
Old 12-15-2011, 10:51:29 PM   #769
AngryFirebird91
Reading your project thread was quite a treat Troy! I have to say very inspiring for someone that wants to build on a budget, I like a lot of your DIY solutions!
AngryFirebird91 is offline   Reply With Quote
Old 12-16-2011, 03:55:37 AM   #770
Nice bird
Old 02-28-2012, 12:34:48 PM   #771
Hoot
Had to prune 600 pics from my image shack account so alot of pics are gone now from my thread. Tried to keep the important stuff.
Old 02-28-2012, 12:50:31 PM   #772
clay's70
clay's70's Avatar
Troy, where have you been!!! Man???
"everything, all the time"
Like Jim Stokkeland, I plumb for my stuff!! (part time)
Pleasants Hardware (full time)
Jane's Build Garage Progress
Marks71BB---I should have drained the sausage!!
clay's70 is offline   Reply With Quote
Old 02-28-2012, 02:40:44 PM   #773
FatnLow
FatnLow's Avatar
Looking good Hoot. That scoop fab turned out great!
FatnLow is offline   Reply With Quote
Old 02-28-2012, 04:52:19 PM   #774
Hoot
Im still around. Posting now and then to try and help others. But not really working much on the car. Need to redo some stuff but not in a hurry. Just enjoying driving her around every week or so.
Old 02-28-2012, 05:42:29 PM   #775
Teamchevy
Teamchevy's Avatar
Great to hear Troy, that's what it's all about!
Dave
1976 LT - 350 4 spd
"BBFL"
Old 03-15-2012, 07:13:11 PM   #776
Hoot
Should have rebuilt my carb when I got it with the engine.....Accelerator pump went bad over winter and was leaking so I had to now.
Throttle response is on a complete new level. Raps up lots quicker too I believe. wow just wow. Im still pumped from that test drive to go get gas and back home
Pulled carb last night. stripped it down and cleaned it up today in parts washer at work. One float bowl was real dirty with crud. Fuel filter before carb was fine except for a couple pieces of rubber from my pushlok hose. I think the fittings cut into it a little. No other crud but that. So the carb was dirty when I put it in I guess.
Anyway, got it cleaned and put back together. Floats adjusted, secondaries adjusted, floats were off a little. I wanted to put my 3/4" adapter(spread bore to square bore) on instead of the edelbrock adapter plate 1/8" thing. Hood clearance was issure before.
So i cut about 1/4-3/8 off the air cleaner flange. and flattened the top just a bit. Now it all clears with the 3/4" open style adapter. let my carb feed both banks
before I had to have my idle mix screws around 3 3/4 turns out to fix a low speed surge. Now 1 turn plus smidgen. And as I said above, the throttle response is a whole new animal !!! Im Happy !!! if ya cant tell lol
Gonna drive it to work tomorrow for another shake down. But im very pleased so far. I had been thinking of swapping my edelbrock for a holley but now I might just keep it..
Old 04-08-2012, 03:26:28 PM   #777
Hoot
Had a slight buck going from cost to cruise at highway speeds with the 3/4" open spacer. I tried every adjustment on teh carb I could. So I tried the edelbrock 4 hole 3/4" adapter. 95% took care of the buck but it whistled like nobodies business under acceleration. So I went back to the 1/8" adapter plate thing. Buck completely gone. Car puts around very very nicely. Never had this good of manors around town before. Dont think it has as much acceleration as it did with the taller spacers but its not much difference. Dont think I can do any better with this manifold.
Today I got fed up with a shifter rattle I have had since I built the car. Took the shifter out. Tore it apart, cleaned it up, and regreased it all with red bearing grease. Rattle is GONE !!! Why didnt I do this a year ago ?
Monday I should receive a power steering pulley. The last piece I need before I can build my brackets. Hopefully by next weekend ill have power steering on the car. Going to be a tight fit with my Windstar dual fans though.
Got a couple more things I want to do but not going to start those till the PS is finished.
Old 04-09-2012, 07:48:44 AM   #778
Teamchevy
Teamchevy's Avatar
Nice to hear you're getting it dialed in!
Dave
1976 LT - 350 4 spd
"BBFL"
Old 04-14-2012, 04:44:25 PM   #779
Hoot
Finished my Power steering install today. Had to move my fans over alittle. The steering box has a big it at the end of it right at 12 o'clock that interfeared with the shrouds. Had to build my own brackets because of all my clearances with the fans also. They turned out really well I think.
anyway its install and bleed. Had to adjust the box a bit. Think I got it really good now. Quite a difference going from 6 turns lock to lock, to 3 turns.
Ill try and get some pics later. My usual camera broke little while back and i need to use the wifes pocket camera. Not sure if it has a card or a cord or what yet LOL. Im not even gonna touch her good camera though.
added pics
Old 04-14-2012, 07:56:25 PM   #780
1981zapper
Looking Good!!
Chris
1981 Camaro Z28 Maroon
-350 4bbl
-TH350 with 3000 RPM Stall Converter
-10 Bolt Posi 3.73
-Wanted Cars & Concepts T-Top Weatherstriping Left and right Side
1967 Chevelle SS (Clone) Oshawa Built Car
-427 .60 over
-Borg Warner Super T10
-Dana 60 3.54 Posi
1981zapper is online now   Reply With Quote
