Old 04-17-2009, 03:38:48 PM   #1
WildBillyT
Summit Cam question
I have a stock '74 350 that's nothing special. Stock 882 heads, 8.5:1, dual plane, Holley 650. Hooker Headers, 4 spd, 4.11 rear.
I want to change the cam since I've got the damper and timing cover off to swap in a new timing set and re-gasket some of the bottom end. I don't really want to throw too much money at it now since I plan on swapping a set of vortecs (or just building up the big block) in a few months. Since I'm placing a Summit order in a few days I though I'd add a mild cam to the list. Summit's stuff is on sale. I have used some of their stuff in the past that has been decent, but never for any internal engine parts.
What do you think? If it sounds like a good idea, how much lift would I be safe with on the stock valve springs? Around .450 or so?
WildBillyT is offline   Reply With Quote
Old 04-17-2009, 06:00:01 PM   #2
docwilcar
With your combo you could get by with a Crane Energizer 100052 cam-216-216-.454-.454 lift 110 lsa. Even though crane is out of business there are a lot of these cams still in parts house inventories for around $130 including lifters. Woud give you plenty of low and mid range. Anything around .450 lift will work fine with your springs as most stock rocker arms only spec out at around 1.4 or so. If you want the Summit cam then the K1102 or K1103 would work for you although I think the Crane would give you a little better performance but I have not used either of the Summit cams. Since you have a free flowing exhaust system I would go with a single pattern cam on a 108 or 110 LSA. I believe the Summit cams are on a 112 LSA. More expensive cams that would work would be the Isky 264 Mega cam 214-214-.450-.450 108 LSA and the Comp 268 HE 218-218-.454-110 LSA . With your 4 speed and 4.10 gears you can get by with more duration than if you had and automatic and less gears. If you want a rump rump idle with a short duration cam try the Elgin E1785 218-218-.450 lift on a 106 LSA. This is a cam with the same specs as the old Crane 274H06 camshaft. $99 from competitionproducts.com including lifters.
docwilcar is offline   Reply With Quote
Old 04-17-2009, 06:07:32 PM   #3
WildBillyT
Doc- Thanks! That Elgin looks like what I want for now.
Old 04-17-2009, 06:08:07 PM   #4
sooner
sooner's Avatar
As far as running a summit cam, I would'nt be scared of it. Although never running one myself, I have seen my share of summit cammed motors around here and have not herd anything bad about them. With the way the economy has been, I have been running alot of house brand parts, although Jegs brand, and have had nothing but good luck with it.
I have ran .480 lift on stock springs in the past, and not had any problems. Im sure thats more than a lot of people consider safe, but it worked for me.
sooner is offline   Reply With Quote
Old 04-17-2009, 06:14:14 PM   #5
WildBillyT
Doc:
Did you mean: Elgin E-1227-P?
Old 04-17-2009, 07:12:24 PM   #6
loudvolvo
ive got a summit cam in my 355 and love it. this is the one i bought
http://store.summitracing.com/partde...4&autoview=sku At first i was skeptical about such a cheap cam but figured i'd try it anyway. Its been in the motor for around 2.5 months and no problems as of yet. good amount of power and torque. Im sure the high dollar lunati and comp cams would be better but this is what i choose and im happy with it
1980 Z28
355 sbc/9.72:1 CR/Edelbrock Performer 600cfm/Edlebrock Performer RPM intake/Procomp Aluminium heads 180cc/1 5/8" headers/Summit Racing Camshaft/SpeedPro flat top pistons/built TH350
loudvolvo is offline   Reply With Quote
Old 04-17-2009, 08:25:48 PM   #7
docwilcar
The Elgin cam # is E1785PM at competitionproducts.com $99 plus shipping.
Old 04-17-2009, 09:12:20 PM   #8
Damon
The Summit K1102 is the same as the Edelbrock Performer cam and would work well in a low compression motor. It's got probably about 10* more duration than the stock cam in your 74.
One step up is the K1103 which is 10* bigger than the 1102 and is about as far as you can go with stock heads (.465 on the exhaust with stock 1.5 rockers). It's really a bit too much in a factory smogger motor without a bit higher stall converter and decent rear rears.
1990 454SS pickup. Sold, but I think she found herself a good home.
78 Malibu. Inherited with only 35K on the odo! Mild 383 with Weiand 142 blower on top. Mid-high 12s on street rubber, bottom 12s on DRs with the trans left to shift for itself. Runs so good I may never drive it again.
"Last remaining QJet tuner on planet Earth!"
Damon is offline   Reply With Quote
Old 04-18-2009, 12:29:16 AM   #9
AJ_72
Those are on sale because (if I'm not mistaken) they're the Blue Racer cams - made by Crane Cams - made for Summit as an in house brand.
AAMOF, that series of cams is sold under many other names by many other distributors as in house cams, and possibly by other companies (such as Edelbrock) as their own.
->Click Here<- for an exhaust clip of my car.
May your nose never itch while you are painting.
AJ_72 is offline   Reply With Quote
Old 04-18-2009, 09:45:31 PM   #10
deputyrob
i used a Summit cam in my 396 and have one in my 350 now, K1105. gonna break it in next weekend.
If you aint smokin the tires....you aint drivin the car!!!
1970 Z28, camaro gold with black stripes.SOLD it...now its someone elses project
1972 sport coupe, 396....11.5 compression, 600 lift solid cam, Holley dp and a Super T10.
deputyrob is offline   Reply With Quote
Old 04-19-2009, 03:56:36 AM   #11
Joe Prather
I used stock springs on a XE 268 cam and had no problems at all. I'm very surprised I didn't run into trouble.
My 57 chevy
http://www.youtube.com/watch?v=5hkqsEzoJQM
79 camaro, 350, flat tops, 305 heads with 1.94 valves. crane energizer 282 cam, stealth intake, edelbrock 600cfm. 2200 stall, 3.73 gears. ran a 14.64@95 mph with 2.73's. should run 14 flat or high 13 now.
04 Grand Prix GT
05 Dodge Magnum R/T
57 chevy 210 2dr. 406 4-speed
57 chevy 210 4dr. 235 powerglide
Joe Prather is offline   Reply With Quote
Old 04-19-2009, 12:49:50 PM   #12
tom3
With that 4;11 gear I like that Elgin cam Doc mentioned. Otherwise with a low compression motor I'd go with a wider lobe centers, 110 degrees or so.
tom3 is offline   Reply With Quote
Old 04-19-2009, 05:01:28 PM   #13
pdq67
BANNED
The old generic Summit Performer cam at 204/214 will do you nicely at 8.5 to 1 in a 350 spec'd at; 204/214, 112/108, .420/.442" lift.
And I figure PROBABLY the best imho for an 8.5 to 1 CR'd engine will be a CC 246PE hy-cam spec'd at; 246/203/263/212, 110/106, .429"/.438" lift.
And Isky'd old 256/262 Supercam spec'd at;
256/202/262/208, 110/??, .425"/.435" lift.
Take your pick w/ the cheap Summit falling right in here by me..
pdq67
pdq67 is offline   Reply With Quote
Old 04-19-2009, 06:00:58 PM   #14
Mwilson
I dont like like them and you can get a "Doug Herbert" cam for the same price with a much better grind, still not "The best of the best" but if we are looking at summit cams herbert has really good ones that blow most budget cams away.
old 72 - now driving a third gen
Mwilson is offline   Reply With Quote
Old 06-05-2009, 04:30:12 PM   #15
tellavision
Registered User
Hey guys,
Any problem with using a little less cam and leaving the high lift valve spring in place? I am replacing a 530 lift cam with a Crane Energizer 100052 cam-216-216-.454-.454 lift.(and lifters) Do I need to change springs? They have less than 1000 miles. I just needed a more street friendly cam for every day.
Thanks for your help!
therontv48@comcast.net
tellavision is offline   Reply With Quote
