10-11-2009, 11:55:31 AM
#1
wright or wrong
what do you think a engine timed at 72* would run like???yes i said 72*....if im wright...thats what i set my timming on before i went to the track and did not realize it till this past friday night when jaywill was over at my shop and was asking me the diff in a dial back/non dial back timming lights....as i was telling him this i was remebering how i did mine ...if im wright i f**ked up big time.....and that explains alot on my track times...and car reacting...i dialed in 36*on the light....and pulled up 36*on the balancer....am i right on thinking that is 72* total timming......instead of dialing 36*on light...and 0*...on the balancer like i should have i know i put 36*on dial and pulled 36*on balancer...  wouldn't that be 72*wrt or wrng???
10-11-2009, 12:26:52 PM
#2
You would figure that if you had that much timing in it that the car would be hard to start and would want to run on after you shut it off.
1977 Camaro Sport Coupe, 430 SBC, TH350, 9 inch 4.10 w/ full spool, 8 point cage. New times to come when the track re-opens
10-11-2009, 12:46:33 PM
#3
i know a guy with a ford that had his around 70 by accident too....he didn't have the best luck with it....this was a couple runs later with the timing back where it was supposed to be.
http://videos.streetfire.net/video/H...lock_61708.htm
9.54 in the 1320 with stock 10 bolt with 342's
10-11-2009, 02:25:45 PM
#4
it is ...eventhou i have retard set inbox[start retard] i thought it was battery problems...had to put charger/booster...on it each time to crank it.. told jaywill i thought i needed new battery..  no after run...just pop thru carb on initial start before charger is added...
10-11-2009, 02:30:26 PM
#5
Originally Posted by Louich
i had my timimg set correct before my msd went out several months back...took dizzy out to check module put it back in and this was the first time i put light on it since then...
10-11-2009, 02:36:51 PM
#6
my god...that block looked split down the middle from what i could see....dam thats a tuff blow....after jaywills shifter broke and he loaded up...so did i maybe that saved me...
Looks Great at Car Shows !!
3 Styles to Choose From: 1970, 1977 or 1978 !!
$17 Shipped in USA or Canada. Easy Ordering !!
10-11-2009, 03:09:08 PM
#7
That's not that unusual with SBF's, I've seen 3-4 do it at my local track over the last couple of years.
10.236@131.52mph with a 150 shot & 11.60@118mph NA
A 10 second street car, eh!
SBC 409, through the mufflers, on DOT radials, you know, like a street car should be.
10-12-2009, 01:24:18 AM
#8
ya they took the engine apart and litterally pulled the halves apart by hand....they now hang on his wall..
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
