Old 12-05-2009, 11:00:06 AM   #1
spicewood1
BANNED
Kerosene torpedo heater problems
Working on an old, but very big kerosene "torpedo" construction site heater. It has worked very well in the past but recently would not fire up. Fuel pump, supply, and fan are all good, has to be the ignition transformer not firing. I can manually light with a propane torch and it will run, just very rich because of no electronic ignition. Well, the darn thing is so old I cannot find a model number or even a name. That said I took off the old heavy ignition transformer and it seems like a pretty simply thing to swap out. Except I cannot find the exact same type - that is, mine has 2 big spark plug type wires coming out the back that go to the igniters. They plug into the back of the transformer and the ends of the wires look exactly like the end of a regular spark plug. All the transformers I can find are the flip down type with coily spring connections. Anybody know where I can find a matching transformer with female snap-in connection on the back?
Paul
spicewood1 is offline   Reply With Quote
Old 12-05-2009, 11:47:00 AM   #2
rscamaro73
rscamaro73's Avatar
Location: Striking fear and destroying the enemy from my borders
You try Grainger yet ? They usually have off the wall crap like that.
I'd look REALLY hard for part #'s....otherwise you're SOL unless you find someone that knows more about them.
A veteran is someone who, at one point in his life wrote a blank check made payable to 'The United States of America ' for an amount of 'up to and including my life.' That is Honor, and there are way too many people in THIS country who no longer understand it.'
http://community.webshots.com/user/rscamaro73
Facebook - rscamaro73
I'm sometimes called Wayne
rscamaro73 is offline   Reply With Quote
Old 12-05-2009, 12:51:19 PM   #3
tom3
Are those igniters actually spark plugs? Or some type of electrode? Common for these to burn at the tip and get out of adjustment and not arc just right. Might take a look at them, on a furnace they would usually be about 1/8 inch apart. Clean any carbon off the electrical path too.
tom3 is offline   Reply With Quote
Old 12-06-2009, 10:41:44 AM   #4
spicewood1
BANNED
Thanks, the transformer is certainly shot, had it tested today. The igniters are not the spark plug type, and they look OK. Tried Grainger, got the pump there years ago. The transformer had some info on it, but not a part #. Got a heating and air friend who told me that these big torpedo heaters are very similar to an old fuel oil home heating furnace. Going to try matching it up at a hvac supply house.
Funny that you can light this thing manually with a torch and it will light and stay lit, and make heat, but the flame sound is not the same roar and it is so rich you have to adjust the flame rod all the way and it still makes your eyes water like Niagra Falls.
Old 12-06-2009, 11:54:38 AM   #5
Twisted_Metal's Avatar
There may be too much air pressure for the flame front to move against the flow and back into the ignition chamber.
I wouldn't use it until you can be sure the kerosene is igniting properly.
Twisted_Metal is offline   Reply With Quote
Old 12-07-2009, 02:07:08 AM   #6
InitialD
Might take a look at your kerosene bottle. Lent one of the torpedo heaters I got from lowes/home depot to a friends dad. they had the exact same problems you described, and we ended up figuring out fuel pressure/tank size was smaller than what was recommended. Note, this was after the heater "accidentally" caught fire while they were trying to get it to work....long, sort-of amusing story....
InitialD is offline   Reply With Quote
Old 12-07-2009, 04:42:18 PM   #7
spicewood1
BANNED
No bottle, this is a BIG one with a 25 gallon kerosene tank on the bottom. Never been lent out and I've always fueled it so I know its good down there. Fuel and delivery is not an issue it is the auto ignition thingy for sure.
