02-23-2011, 02:37:19 PM
#16
Originally Posted by White81Z
I'm not so sure that is a good idea posting everything you need to create another car. Just the little bit of info posted so far is everything someone needs to build a car including new VIN and trim tags.
Just looking at this from another view.
Rick H.
First off its not the entire VIN,and second,you can get the entire VIN by walking up to any car at a car show,or just making one up. If a state doesnt check records outside their state,then you have a 50:1 chance(very good odds) that just making a Camaro VIN up will get you papers. I could make up a number,1=chevy,Q= base model, 87 = 2 door coupe, F= 307 engine 3= 1973,N= Norwood and then add any 6 numbers I want and have a legit vin number. So if I owned a 70 thru 73 Camaro I could ujust walk into the DMV and tell them that my car has a VIN 1Q87f3N123456 and they will just make up a title. It could be somebody's car from any state,or a car that never even existed(123456 could have been used on a type LT which would start with 1S87K3N. Either way,what is posted here is less info then is what is on the Z/28 registry.
You would also need a source for repop VIN tags. If thats the case,then we are all in trouble since anybody could repop a 72 and later tag to say they had a Z/28 engine and have a Z/28. Anybody could make a tag for a 70-71 with their last 6 digits with a V* prefix in front of them to make their 6 banger into a V-8.
1973 Camaro hot rod owned since 1989 runs high 12's. Mild 408 small block,th350,3.08 gears,ice cold a/c pumpin system ect.
1973 Firebird owned since 1994 runs mid 10's on motor and mid 9's on a 250 shot. BBC 439 2 speed,4.88 12 bolt,3600# full street car.
2011 Camaro RS,Jewel Tint.
2003 Silverado HD2500 and Wife's 2004 Malibu Maxx. Keeping my Family ALL GM!!!
02-23-2011, 02:54:08 PM
#17
Huge thanks to ZZ430. I think we have concluded our 1979 Camaro list. Maybe one July car,but thats all we need
02-23-2011, 05:13:57 PM
#18
1981 Z28
VIN 131592 (Norwood)
Date 05A
Body 206626
Interesting it has the same date code as on of John's cars with a body number earlier and a VIN later. They probably were on the assembly line at the same time.
02-23-2011, 05:26:49 PM
#19
Is the date code on the build sheet?
(I believe the body # is on it.)
I ask because I still have a build sheet from my 78 but I don't have the trim tag info.
02-23-2011, 05:51:31 PM
#20
Thanks,so far so good. I just drew up a few sheets of paper with 12 month boxes for each year,and have been filling them in. Once I get it looking full I will try and post it. Thanks,this should be cool. Once done,we can always referance it to conact other owners of cars with close build dates to ours when looking to figure out mid year changes on cars.
Twisted,any info is fine. The last 6 of the VIN and build date are probably the most usefull. Like I said,it will help in the future when trying to make heads or tails of the oddities our cars have as things changed during the year.
02-23-2011, 07:10:39 PM
#21
1978 Z28
VIN 636244
Date 08A
Body 314078
1979 Sport Coupe (crushed)
VIN 613983
Date 06B
Body 224530
1981 Berlinetta (crushed)
VIN 182817
Date 07B
Body 182817
If you're able to find the build date on a build sheet please send me a private message as I have a large collection that I can share.
1978 Chevrolet Camaro Z28
1999 Mazda Protege SE
02-23-2011, 07:33:47 PM
#22
1981 Sport Coupe
Vin 100801 (LA)
Date 08 D
012273
ill try to get my Berlinetta up soon. just need to get the build date off the trim tag
02-23-2011, 08:44:41 PM
#23
Rich - here is the '79 July car you need:
1979 Z28
VIN 640536 (LA)
Date 07C
Body 289130
02-23-2011, 08:53:24 PM
#24
Rich, here are the rest of my Gen 2 Camaros:
1970 SS396
VIN 518909 (LA)
Date 04D
Body 17733
1970 SS396
VIN 521534 (LA)
Date 05B
Body 20469
1971 RS
VIN 501578 (LA)
Date 08D
Body 01610
1974 Z28 TYPE LT
VIN 147887 (Norwood)
Date 01C
Body 119490
1974 Z28
VIN 172902 (Norwood)
Date 02C
Body 160605
02-23-2011, 09:21:16 PM
#25
Awsome. The 70-81 has a strong showing on the list and the 74's are doing surprisingly well. This could also be usefull in comparing Norwood and LA cars in the late 70's years. I am thinking of adding some space to the final list to put in the user name of the owner so that if in the future somebody wants to contact them about something on their car they have a name to PM.
Nasty Z has been the go to place for 2nd gen info,but nobody has a CRG type database for our cars. Maybe as we develop stuff like this we can start documenting all those oddities about our cars so in the future we car restore them correctly.
02-24-2011, 08:36:27 PM
#26
dug out the info for my donor car
1980 Berlinetta (crushed)
VIN 566188
Date 05A
Body illegible in photo of tag
02-24-2011, 09:13:12 PM
#27
date code on build sheet
I'm not sure about date codes on the build sheet, but my car was built first week of may according to my trim tag (05A)
On the top of my build sheet it says 05-07. Maybe that is the actual date?
I have another photo of a donor car build sheet that had 06-17 on the top left, but I don't have trim tag info to compare that to. The donor car I had the trim tag date had an unreadable build sheet.
My brother's car has a build sheet that says 02-27 in the top left square. I don't have trim tag info for this car available right now.
Those numbers sure do look like dates to me. It would be a huge coincidence for that number on my build sheet to match the date on my trim tag if it wasn't the date.
Maybe a few others can check their build sheets.
02-24-2011, 11:29:07 PM
#28
1978 Z28
VIN 572537
Date 03C
Body 195405
02-26-2011, 05:17:19 PM
#29
1981 Z-28
VIN - 113712
Date - 10E
Body - 056402
L = Van Nuys/LA
02-26-2011, 06:21:50 PM
#30
Thanks,keep them coming. I will be updating the list in work on Monday. I may go over to the Z/28 registry and get some numbers from there just to fill in the 70 thru 73 section for the time being.
| Thread Tools |
| Display Modes |
Linear Mode
