Go Back   NastyZ28.com > General Topics > Tips 'n' Tricks Topic > Detailing Topic
Old 04-10-2011, 01:22:41 PM   #1
delete-Z
Question water spots on glass
how do you get water spots out of the glass,like on door glass or rear window glass? it is from hard water in arizona! just will not come out!
71' CAMARO Z-28 350 Lt1,350 trans 373 rear
89' DODGE DAYTONA SHELBY 2.5 turbo,auto
03' GMC ENVOY XL
delete-Z is offline   Reply With Quote
Old 04-15-2011, 08:51:39 PM   #2
delete-Z
any idea's ?
03' GMC ENVOY XL
Old 04-16-2011, 12:19:34 PM   #3
fast12
I use Water spot remover from Malco. malcopro.com 300-753-0361
This stuff is easy to use and works great
fast12 A.K.A. THREAD KILLER
1971 Z28 LT-1 matching # SOLD
1971 RS/Z28 LT-1/M21 matching # SOLD
1971 Z28 LS6/M22
allgencamaros.com
fast12 is offline   Reply With Quote
Old 04-16-2011, 12:38:22 PM   #4
c120cut
lime away or crl somtime jet dry will work
c120cut is offline   Reply With Quote
Old 04-16-2011, 01:11:54 PM   #5
firebird69racer
I have used a clay bar on mine. Worked great. I use it with window cleaner not the detail spray that comes with it, and don't use it on your paint afterwords.
firebird69racer is offline   Reply With Quote
Old 04-16-2011, 01:14:24 PM   #6
wiseryder
wiseryder's Avatar
denatured alchol
They all should've had Cowl hoods ......
Scott
wiseryder is offline   Reply With Quote
Old 05-07-2011, 07:21:49 PM   #7
alphaenvirmgt
You can clean outside of windows using XXXX or XXXXX steel wool. Rub lightly. Will also work on inside but not if have aftermarket tint!
Conrad
1974 Z28, LT, ordered the car, 4-spd w/Hurst, A/C, #'s match, 105k mi, 96 Vette wheels, Edelbrock ProFlow EFI, dropped B-Car spindles/12" frt disc, VBP upper ctrl arms, 1.25" GM front bar, HA rear bar, poly end links, Koni adj, leaf spring frt mount@Guldstrand, Hooker Comp headers/2.5" exhaust/X-over, Dynomax SS mufflers, 81 2.5" tailpipes/CA hood, T/A rear disk/MC/booster, Optima-trunk, Nardi.
alphaenvirmgt is offline   Reply With Quote
Old 05-07-2011, 09:30:09 PM   #8
vfitom2aol.com
Steel wool is what I use also.
vfitom2aol.com is offline   Reply With Quote
Old 05-07-2011, 10:04:14 PM   #9
fbody_mike
Bon Ami. GM used to recommend it in the owners manual. I used it on my daily driver to get rid of all the crud that windex couldn't touch.
fbody_mike is offline   Reply With Quote
Old 05-08-2011, 08:27:04 PM   #10
rs454
if you use the steel wool method be sure to use ALOT OF GLASS CLEANER..even though 4and 5x is very fine it may still scratch the glass...
rs454 is offline   Reply With Quote
Old 05-08-2011, 11:04:11 PM   #11
Red 69
My vote is for Bon Ami. It will take all the film, water spots, bugs and about anything else off and not scratch the glass. I sprinkle some on a damp sponge and have at it.
Red 69 is offline   Reply With Quote
Old 05-09-2011, 07:02:18 AM   #12
MassD
Just get some rubbing compound and work it into the glass by hand. Comes out like glass lol
MassD is offline   Reply With Quote
Old 05-09-2011, 08:52:47 AM   #13
hoov81
Wow steel wool on glass sounds risky
hoov81 is offline   Reply With Quote
Old 05-16-2011, 05:12:58 PM   #14
theflash
theflash's Avatar
I found that rain-X will sometimes remove water spots
theflash is online now   Reply With Quote
Old 05-16-2011, 08:37:05 PM   #15
I use 3000 grit micro mesh
