Old 02-05-2006, 01:01:55 AM   #1
paulzman
71 Z28 fender eblem placement
I am trying to figure out exactly where to drill the holes for the Z28 fender emblems. I have the assembly manual, but cannot make sense of that. Does anyone offer a template? Or perhaps someone can tell me many inches the emblem sits below the mid point of the fender and how far from the door edge of the fender. Thank you!!!
paulzman is offline   Reply With Quote
Old 02-05-2006, 01:48:22 AM   #2
m pozzi
Moderator, powered by macaroni and cheese
Thumbs up
Hi Paulzman,
I have a 70 Z28 and will take measurements for you and post them tomorrow. My fenders are stock and predrilled so you'll get accurate measurements.
Mary Pozzi
P.S. Welcome to the site . . .
1973 Camaro RS, 1969 Camaro SCCA/Trans-Am vintage racer, 1989 IROC-Z R7U 1LE Players Challenge car, and a 2002 Camaro SS.
MCJ: "MARY! MARY! I DON'T LIKE THIS, MARY! I LIKE ORGANIZATION!!"
first watch http://www.youtube.com/watch?v=JkmLy99TyXU
then watch http://www.youtube.com/watch?v=BWR3MZd3oz8
"It's not a horse ... you can't train it!!!"
m pozzi is offline   Reply With Quote
Old 02-05-2006, 02:20:42 AM   #3
Z-WIZZ
some of the guys here use the stick on kind. no drilling the paint job.
the more im around people, the more i like my dogs
“Extinction is the rule. Survival is the exception.” Carl Sagan
“Racing is life. Anything before or after is just waiting.” Steve McQueen
'70 Z 4sp
jeff
Z-WIZZ is offline   Reply With Quote
Old 02-05-2006, 02:36:22 AM   #4
paulzman
Mary, Thank you very much! Paul
Old 02-05-2006, 02:33:17 PM   #5
Bad 406
He who uses the search feature will find the answer!
http://www.nastyz28.com/forum/showthread.php?t=37769
Bad 406 is offline   Reply With Quote
Old 02-06-2006, 01:43:34 AM   #6
m pozzi
HI Paulzman,
I measured my '70 Z28 front fenders and here goes . . .
Right front fender emblem placement: Measure forward along the fender belt line, or crease, starting at the rear of the fender in front of the door. Your markings should be at 6-1/4" and 9" respectively along this line. Both holes should be drilled 1-7/8" below the line, or crease, at the above measurements. When you get to the 6-1/4", your first hole will be 1-7/8" below that. Your second hole will be 1-7/8" below the 9" mark on the crease.
Left front fender emblem placement: Measure forward along the front fender crease starting at the rear of the fender in front of the door. Your markings should be 5-1/2" and 8-1/8" respectively along this crease line. Again, your holes should be drilled 1-7/8" below these measurements for proper emblem placement.
I would doublecheck with YearOne and Classic Industries to ensure that the '70 and '71 Z28 emblems are the same as this may affect my measurements above. I tried for photographs but couldn't insert the appropriate text so had to go to Plan B instead and try to write it out. Hopefully, it is understandable but if not, please let me know and I'll try again.
Mary Pozzi
Old 02-06-2006, 10:43:48 AM   #7
COPO's Avatar
Why not use a Taylor's measuring tape and tape both ends on the fender then snap a photograph.
Mark
70 Z28, M22, 3.73-Lunati 20120121 Retro Roller Cam
Testing out Brad Penn SAE 30 HP Oil
http://my1970z28.com/COPO/index.htm
Prev Z/28's
1968 Z/28
1971 Z28 4-pd
Z28's I ordered new:
1977 Z28 4-spd w A/C
1978 Z28 4-spd
1980 Z28 4-spd
COPO is online now   Reply With Quote
Old 02-06-2006, 10:18:21 PM   #8
paulzman
Thanks everone - I drilled the holes and looks great.
Old 05-31-2014, 01:48:33 PM   #9
rwflather
These posts are old, but still useful!
rwflather is offline   Reply With Quote
