Go Back   NastyZ28.com > Body & Chassis Restoration > Interior Restoration
Old 05-15-2007, 11:33:13 PM   #1
70camfan
Green Interior Paint question;1970 code 723
Does anyone know what supplier has the closest paint match (spray) for a 1970 code 723 Green standard interior? The color is dark green. I have not found a match that appears similar to my door panel pieces. The panels appear lighter than the paints. Is it due to age and sun, or is the paint color not right?
70camfan is offline   Reply With Quote
Old 05-16-2007, 02:39:27 PM   #2
RS70Z28
If it is still available, Ditzler code DIA 44173 dark green poly was used on many interior parts and was a low gloss color (if you want I can give you all parts that were painted this color). Ditzler code DIA 44169 dark green poly was used on: upper instrument panel (exposed areas), compartment front panel, vehicle identification plate, back window header lace escutcheon, rear seat to back window panel reinforcement, window lower frame,and instrument panel radio speaker grille and was flat "O" gloss. Both paints were used with trim combination 723.
RS70Z28 is offline   Reply With Quote
Old 06-17-2012, 01:40:24 PM   #3
Cue-Ball
I'm going to resurrect this thread from the dead to ask a related question. The above answer about Ditzler 44173 worked great for the metal interior panels, but what about the soft and vinyl parts? I bought OER M24 Dark Green interior dye, thinking that it would be the right color for my dash, door panels, sail panels, etc. It's not. It's a dark green metallic color, but is not the *correct* color. It has a very high metallic content and looks very "silvery", as noted in the pictures below.
Here's the M24 paint/dye on the back of one of my sail panels. You can clearly see the color difference.
And here's the completed dash in contrast with my rear panel (green plastic) and A-pillar cover (painted using the correct interior paint color code for hard panels).
Does anyone know a supplier for the correct paint to redo the plastic panels and/or dash? I've been unable to find anything online through any of the regular vendors, and can't seem to find a paint code either.
My '70 Camaro build thread
My '80 Cheyenne build thread
"I only wash my vehicles in the tears of young children. Their sorrow brings out the shine. Plus, they are a renewable resource and are carbon negative". -BusDriver
Cue-Ball is offline   Reply With Quote
Old 09-13-2012, 04:56:17 PM   #4
stphilli
I am having the same issue. I am also looking for the correct seat cover color. Did you ever find out an answer? Is the paint code referenced above still available? If so, from where?
stphilli is offline   Reply With Quote
Old 09-13-2012, 11:11:35 PM   #5
Cue-Ball
I do not think I ever stumbled across the correct colors. The problem stems from the fact that multiple shades of green are used in these cars (the upholstery, the door panels, the plastic panels, and the dash are all different shades) and that my car wasn't original when I bought it (the upholstery and dash had been changed). All of the original cars I've seen have been so old and rotted that you really can't tell what the correct color is supposed to be. Here's what I did, and what I can tell you.
Ditzler 44173 is the correct color code for the "hard" parts in the car. A-pillar covers, rear window lower steel trim, etc. It's a perfect match, as far as I can see and I'm very happy with the color.
OER M24 Dark Green interior dye is a match for the silvery-metallic seat upholstery that you can get for these cars. If you look at the attached photo you'll see that this dye (the center portion of the C-pillar cover is dyed, which should be obvious) is a very good match for the upholstery kit that's available. Note that there may be more than one dark green upholstery kit for 1970 cars. I'm not sure and really don't remember since I bought mine over a year ago.
I used another paint, SEM C-VP5084 Dark Midnight Green Metallic, on my dashpad. It's supposed to be for a 1969 Camaro, but it's about the only other dark green vinyl I could find that I thought would be even remotely close. It's much darker than the color of my vinyl door panels or my hard plastic interior parts (both of which are pretty close in color). I wound up using it on the dash anyway, because I *needed* to re-dye my dash and couldn't find what I thought was the right color. The following photo shows one of my door panels compared to the re-dyed dash. You can easily see how much darker the dash is.
In the end, I was unable to find a vinyl dye of the correct color. I suspect that the only way anyone will get it is to have something custom mixed using a hidden, non-faded portion of interior trim as a source color. I'm good friends with a painter and he was not able to do this for me, so I'm not even sure how a person would go about having a custom dye made. I'm going to wind up just making my plastic pieces look as good as possible and buy replacement door panels that are hopefully the right color. I figure that's the best I can really do for now.
Old 09-18-2012, 07:12:53 PM   #6
stphilli
queball where did you get your seat covers?
Old 09-18-2012, 10:04:15 PM   #7
Cue-Ball
I *think* I got my seat covers through Classic Industries, but it's been a long time. I'd have to check through my receipts to be sure.
Edit: Also, I'm not sure these are actually the correct original seat covers. I've seen a couple of green interior cars with seat covers that look a different color and pattern. I'll try to round up pics to post.
