horn
Discussion in 'Interior Restoration' started by steve.swiontek, Oct 20, 2003.
  1. steve.swiontek
    steve.swiontek New Member
    Oct 20, 2003
    Devils Lake, ND, USA
    I have found all of the necessary parts for the horn in a 77 tilt steering column, but it continue to make contact and engages the horn relay without pressing on the horn button. What is wrong?
  2. 79linetta
    79linetta Veteran Member
    737
    Jul 1, 2003
    leeds,al,usa
    is the spring wore out?if it doesn't have enough tension it will allow it to contact easily.
  3. HCKY23
    HCKY23 Veteran Member
    2,032
    Nov 30, 2000
    Levittown, New York
    are you sure you don't have the springy metal piece in backwards. I accidently did that once and had the same result.
