leaking th350
Discussion in 'Transmission & Driveline Topics' started by kaoscamaro79, Feb 19, 2012.
  1. kaoscamaro79
    kaoscamaro79 New Member
    Feb 19, 2012
    SATSUMA FL
    my trans started leaking about a week ago and hasnt been drivin much since, i have replaced the trans pan gasket twice(no change) so today i i picked the car off ground and put in gear ,as i looked under the car i noticed a stream coming from behind the modulator from the inset circle piece i guess the clutch? it still shifts ok but it looses fluid way to quick ...is there an oring or gasket to replace or do i need to go and rebuild?
  2. Louich
    Louich Veteran Member
    2,412
    Mar 8, 2004
    Arthur, Ontario
    there is an oring on the modulator, if its further ahead on the pass side, there is an accumulator cover and it also has an o ring on it.
