New wiring
Discussion in 'SiteTopic' started by 78TYPELTLOVER, Dec 17, 2016.
  1. 78TYPELTLOVER
    78TYPELTLOVER New Member
    Apr 8, 2006
    I'm restoring my 78 Camaro I bought a 22 circuit wiring harness and the fuse box is much larger than the stock one any suggestions on where I can mount the fuse box where it will be out of the way but easily accessible
  2. 71 rs BBC
    71 rs BBC Veteran Member
    101
    10
    Nov 28, 2016
    Indy
    When you buy a aftermarket wiring harness The wires are cut to length for the box to be mounted as close as possible to the stock location on the fire wall. There's usually a little extra on each wire but not a whole lot. With the Old wiring out of the way just fit it the best you can. Good luck!
  3. budro6968
    budro6968 Veteran Member
    267
    8
    Apr 2, 2016
    Jax Florida
    Does it fit the original hole in the fire wall Can you plug it together? Is it that much larger that it interferes with anything. I guess you can't return something like that.
  4. John Wright
    13,750
    19
    Aug 9, 2002
    Rustburg, Va
    Good question....watching for answers to that one.
