U Joints
Discussion in 'Transmission & Driveline Topics' started by GearHead72, Jan 3, 2005.
  1. GearHead72
    GearHead72 Veteran Member Gold Member
    921
    May 24, 2004
    Shawnee, KS
    I am getting ready to install a 3.73 posi into my 72 Camaro. The rear is out of a 77 Z28. If I have my facts right, the u joints are different...I either have to have my driveshaft modified or get a driveshaft from a later model. Am I correct?
  2. El Guapo
    El Guapo Veteran Member
    1,531
    Feb 18, 2004
    Greensboro, NC USA
    You need a "conversion" u-joint. They sell them almost everywhere. I think it's 1310 on one side and 1330 on the other, but I could be wrong. Do a search on "conversion u-joint" and see if that helps.
    [This message has been edited by El Guapo (edited January 03, 2005).]
  3. night rider
    night rider Veteran Member
    6,401
    Aug 6, 2002
    Bremen, Ga
    El Guapo is right, you need a bastard joint (conversion u- joint)
    Every brand has them. You just have to know what you need, or find a parts guy in a store thats willing to help.
    When I done my 88 camaro, I had a hard time finding a U joint to go from the stock little u joints on the 7.5" rear/driveshaft with inside clips to the big joints of a th-400 trans yoke with outside clips.
    I got lucky. A real car guy works at my local auto zone, and me and him spent about 30. min sitting on the floor in front of the u joints going through each one till we found the sizes I needed.
    As a note.. Dont buy cheap joints, or ones with the zerk grease fitting in them. Get the "brute force" joints form auto zone. Forged solid body, bigger bearings, etc
    [This message has been edited by night rider (edited January 03, 2005).]
  4. angel71rs
    angel71rs Veteran Member
    1,343
    Jul 28, 2002
    El Paso, TX
    3022. Question gets asked about once a month. [​IMG]
  5. retorq
    retorq Veteran Member
    4,920
    May 13, 2003
    Kingman, AZ
    Get a brute force for the front, not the rear. I'ld rather blow a $15 cheapo UJoint than twist my drive shaft or grenade my rear end. Just my $.02. [​IMG]
  6. GearHead72
    921
    May 24, 2004
    Shawnee, KS
    Thanks for help everyone!
