08-09 Tahoe 6.0 ls engine with 243 heads. HELP Please
Discussion in 'High Tech Retrofits' started by Tpichevy, Oct 31, 2016.
  1. Tpichevy
    Tpichevy Veteran Member
    501
    16
    Jun 21, 2016
    Boise id
    Found a 6.0 on Craigslist from a 08-09 Tahoe with 65k complete asking 2,300$. Has the 243 heads. With that said I have found that these year tahoe engines had a problem. " #Pip4525a " http://www.tahoeyukonforum.com/threads/spun-bearing.55799/ . Anyone know if this is a motor I should stay away from or get it for a 1970 swap? Been loosing sleep over this deal help me ha-ha
  2. Pierre74LT
    Pierre74LT New Member
    12
    Dec 28, 2012
    Qc
    this bulletin is for tahoe hybrid with no provision for starter or generator
    "2009 Cadillac Escalade Hybrid
    2008-2009 Chevrolet Silverado Hybrid, Tahoe Hybrid
    2008-2009 GMC Sierra Hybrid, Yukon Hybrid
    with 6.0L Engine (RPO LFA) Built Before 9/2/2008
    Important: If the vehicle is built after the breakpoint above or if it is not built with Engine RPO Code LFA, this PI does not apply. "
  3. Tpichevy
    501
    16
    Jun 21, 2016
    Boise id
    Where do I find the RPO code?
  4. Pierre74LT
    12
    Dec 28, 2012
    Qc
    the rpo LFA is for hybrid vehicule only. the best way to decode RPO is with the VIN
  5. Tpichevy
    501
    16
    Jun 21, 2016
    Boise id
    The motor is pulled already.... no vehicle to check vin....
  6. Pierre74LT
    12
    Dec 28, 2012
    Qc
    the tahoe 09 have 3 models of 6.0 liters. the LFA has no provision for 12 volts starter, the L76 is an aluminium block with AFM, the LY6 is an iron block without AFM.
    hope this can help you
