1/2 inch fuel line
Discussion in 'Engine Topic' started by rhino370, Jan 5, 2017.
  1. rhino370
    rhino370 Member
    83
    Oct 18, 2006
    have read everywhere that you need 1/2 in line to support 700hp, yet 90% of the fuel pumps and regulator fittings are 3/8, doesnt that restrict the whole thing ?
  2. muscl car
    Not unless you get a fuel pump with 1/2" Dia fittings
  3. mrdragster1970
    Some of it is about volume, and how quick the recovery is.
    A small line has very little volume, a larger line has volume and can catch up quickly.
    73 Z likes this.
  4. Notalent
    Notalent Veteran Member
    487
    Jan 27, 2010
    Dallas/LBC
    If you go with that 1/2" fuel line, keep in mind the volume that's added and a higher flowing fuel pump is needed.
  5. Notalent
    487
    Jan 27, 2010
    Dallas/LBC
    Those larger fuel pumps will have the larger inlet sizes for it as well, like the Holley 12-454-20 170GPH will have -8 inlets (1/2")
  6. rhino370
    rhino370 Member
    83
    Oct 18, 2006
    those are mech fuel pumps im looking for elect , confused how they say support 700hp yet dont have the large fittings to supply fuel to do it
  7. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,017
    Sep 22, 2007
    Blind Bay, B.C.
    Small fittings = need higher pressure. Large fittings = need higher volume.
    Just saying.
  8. 77 cruiser
    77 cruiser Veteran Member
    440
    12
    Nov 17, 2006
    Frostbite Falls MN
    3/8 NPT the OD is .675.
  9. 450bench
    450bench Veteran Member
    2,903
    Feb 25, 2002
    memphis, tn-shelby
    Quick story about 1/2 inch fuel line.
    Years ago I had a nice 72 Vega. 11 to 1 LT-1 motor with Ultradyne 255/263 626 solid roller. Car ran 6.90s all day. 3/8 fuel line with one Holley blue pump, original z28 intake and original 4490 780 Holley. Brookshire told me to run 2 blue pumps and 1/2 fuel line, along with 2 regulators. He is a brilliant guy, really is, so I tried it wanting to go faster. Spend the money and did it. Car ran exactly the same. Exactly.
    Obviously all situations are different but wanted to share the story.
  10. G72Zed
    G72Zed Veteran Member
    400
    25
    Sep 8, 2015
    good story thx for sharing that 450bench
    That Says allot on what is actually needed for fuel volume/supply, a 10.90 car with only 1 blue Holley and 3/8 line was enough to supply all the fuel that the engine required, and then some.
