10:1 CR 383 and 93 pump gas?
Discussion in 'Engine Topic' started by boogie, Nov 27, 2012.
  1. boogie
    boogie Veteran Member
    235
    May 29, 2011
    louisiana
    Wanted to see if some of you guys are succesfully running a 10.1:1 CR on 93 pump fuel. Here are the details:
    383 SBC with 6" rods, Probe 12.8cc dish pistons, "906" Vortec heads that cc just under 63. Pistons are .020 below deck and using a .028 GMPP gasket.
    The cam is a bullet HR 278/286 on a 108 lsa
    DCR computes to 8.13 if you look at that.
    Tell me some good stories
  2. twozs
    twozs Veteran Member
    8,817
    168
    Aug 5, 1999
    hopewell jct ny
    my ls1 2001 camaro has 10.1 to 1 from the factory and it runs fine on 93 (actually so does my nissan 3.5 altima)
  3. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    11:1 compression using 93 octane and it works just fine.
    10:1 is a piece of cake/
    91 octane may work too.
  4. boogie
    235
    May 29, 2011
    louisiana
    Its a carbed motor BTW.
  5. cmonson
    cmonson Veteran Member Gold Member
    4,134
    Apr 7, 2006
    Calgary, Alberta
    10.5:1 on 93 here. No issues.
    Cam selection is everything...
  6. boogie
    235
    May 29, 2011
    louisiana
    Mind posting some engine details? Iron heads? Cam specs?
  7. Damon
    Damon Veteran Member
    12,939
    21
    Nov 16, 2000
    Philly area
    It should be OK. Check your cranking compression. If it's north of 200 PSI you may have issues if you "lug" the engine below ~3000 under significant load. Cranking compressions of 210, 220, 230 PSI or higher is where carb'ed Gen1 small blocks have issues on pump gas on the street (especially after they get some miles on them and carbon builds up in the chambers and piston faces). Otherwise, it seems in the realm of sanity to me. I think you'll be fine.
  8. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    The 11:1 motor uses a 650 dp, see sig.
  9. deathmunchy
    deathmunchy Member
    39
    Aug 9, 2012
    memphis, tn
    Whats the highest Compression ratio you want to use on pump gas? I was reading somewhere static isn't so much relevant here as dynamic and that a 9.5:1 Dynamic is where you start getting into 93+ territory. Is that right?
  10. Todd80Z28
    11,531
    233
    Jun 11, 2002
    Northern VA
    It's more like 8.0:1 actually. A 10:1 engine with a 215° @ .050" cam is going to be there.
