10 Bolt Floating Axle
Discussion in 'Transmission & Driveline Topics' started by AlbertaZ28, Jan 20, 2019.
  1. AlbertaZ28
    AlbertaZ28 Veteran Member
    257
    Aug 17, 2010
    Fort Mcmurray, Alberta
    So I thought I had a brilliant idea today about bolting a newer style Corvette or Camaro wheel bearing assembly onto a 10 bolt axle. After a lot of searching I found that someone has already done it. Has anyone tried this kit from Millerbuilt? It seems like a great idea to solve some of the short comings of the 10 bolt.
    https://millerbuiltusa.com/12b/
  2. dave@ztech
    3,427
    712
    Mar 27, 2016
    NY
    Kit looks good, will be interested in the comments.
  3. badazz81z28
    16,685
    463
    Las Vegas, NV
    Don't know I would buy and install that kit on a OEM housing. Any reason why you want to go this route? I would look to someone who can build you a new housing with the floater ends installed. DSE comes to mind...
    Is the kit you linked a bolt on kit?
  4. AlbertaZ28
    257
    Aug 17, 2010
    I am installing 6th Gen Brembo's on the rear to match my fronts and I've been doing some research on brake pad knock back and the different options to reduce or eliminate it. This solution came up which would also remove the c-clip axles, and I was curious if anyone has any experience with it. It is pricey though. I'm starting to think the pad knock back on the street might not be a big issue.
  5. badazz81z28
    16,685
    463
    Las Vegas, NV
    For a street car, not really. Really not so much for your weekend Autocross car either. I run a 9” solid axle and don’t notice any issues. A true competion car could benefit from it, when every second counts with increased safety.
  6. Skip Fix
    Skip Fix Veteran Member
    2,180
    23
    Mar 21, 2007
    Katy,Texas
    For just pad knock back I would think just weld on positive retainer ends using the 3.150 taper bearing would do the trick and be a little easier install.
  7. badazz81z28
    16,685
    463
    Las Vegas, NV
    For a C-clip axle, there is a lot of fore and aft play. With the Ford ends (at least on mine) with the tapered bearings...there is no movement in those axles. Under the forces of driving there is probably very little to matter. You know me though...I predict a floating axle in my future.
  8. woody80z28
    5,570
    57
    Sep 8, 2004
    walton, ny usa
    That's a pretty cool little kit. Makes me want to fab one.
    I don't see the axle stubs listed as included. So I guess you call up Moser and give them the splines of the diff and let them know it's a Corvette hub on the other?
    NVM...there's an axle link on the page. $400 for a pair.
  9. AlbertaZ28
    257
    Aug 17, 2010
    You buy the axles separate from Millerbuilt. They are $400, listed under the Axles drop down box.
  10. badazz81z28
    16,685
    463
    Las Vegas, NV
    I might actually look into this...they have a ford 9" version...direct bolt on can't be bad...My axle retaining plates are bolted on...
