100 horsepower for $830 with a warranty preserving tune
Discussion in 'The BS Topic' started by 351maverick, Mar 15, 2017.
  1. 80sz
    80sz Veteran Member
    3,216
    429
    Feb 2, 2014
    Buffalo,n.y.
    This will be most viewed thread today. Maverick loving it,man can stir a turd like no one else! I'm hooked already .... Gonna get exciting!
    351maverick likes this.
  2. 351maverick
    351maverick Veteran Member
    3,660
    418
    Aug 11, 2010
    erie, PA
    this is the graph from Ford (it's in that first link)
    right now (no tune yet, on stock 220 Pirellis) I can get out of the hole pretty good....sub 2.0 60 foot time, but that's leaving at idle - there is just enough turbo lag to prevent blazing the tires
    ideally I'd like to leave right at 2200 rpm, peak torque, but I'll need at least drag radials
    Buickfunnycar likes this.
  3. 351maverick
    3,660
    418
    Aug 11, 2010
    erie, PA
    all from 138 cubic inches, that's mind blowing
  4. DENALI
    DENALI Veteran Member
    1,096
    19
    Nov 4, 1999
    Sonova Beach
    So if this was "violently zippy" what will it be now? :D
  5. 351maverick
    3,660
    418
    Aug 11, 2010
    erie, PA
    my plan is to let the 1/4 mile timeslips do the talking for me ;)
  6. 80sz
    80sz Veteran Member
    3,216
    429
    Feb 2, 2014
    Buffalo,n.y.
    Am I figuring this correct? 330/138= 2.3 hp per cubic inch. Holy moly if I did math right
  7. LayZ
    LayZ Veteran Member
    1,854
    15
    Jun 9, 1999
    NJ. US
    I don't know much about ford turbo charging but i do know dodge. In my srt-4 you got a $30 boost controller you plumbed in to your turbo charger with vacuum hoses. You then got a new waste gate actuator to hold the boost level instead of it dropping off. Problem with the srt was it wold boost to 17lbs but sharply drop off to 10-14. That would make 300 hp out of a 240hp rated 2.4 motor. We did all that for $80, then we did a 3 bar map clamp and we could pull 17lbs all the way through. Problem we had was the stock ECU. for safety reasons it killed boost past 17lbs because they had that 10year-70k mile warranty. I have mine turned up to 23lbs and a 50 trim turbo at 440hp, i go threw turbos every year because i didn't install a turbo timer, that and i don't change the oil like i should. i'm a 2800lb car.
    IF this had been a rwd car it would be insane. The dam front wheel drive kills everything. Can't get traction to save it's life and the wheel hop is bad, even with solid mounts all around.
  8. vegas1974z28
    4,661
    123
    Jan 10, 2002
    Las Vegas,NV
    That is a lot of stress on that little motor...I wonder how long they will last?
    My guess 36,001 miles or 3 years and 1 day.
    CamaroGP and Chevrolaine like this.
  9. Fbird
    4,172
    705
    Feb 12, 2011
    atlanta, ga
    :rolleyes::eek::dumper:
    yup!
  10. BLUE72CAMARO
    BLUE72CAMARO Veteran Member Lifetime Gold Member
    4,753
    179
    Mar 15, 2004
    Bunker Hill, IL
    HOLD THE PHONE... Thought you were already running a tune and in the 12's or were you just shooting off at the mouth as usual a few months ago???
