$1000 '70 LS1/T56 swap
Discussion in 'High Tech Retrofits' started by spav350, Feb 25, 2012.
  1. RS1970
    RS1970 Veteran Member
    500
    Sep 1, 2011
    Washington
    Pm sent. I have some info for you.
  2. spav350
    spav350 Veteran Member Lifetime Gold Member
    601
    Apr 8, 2009
    Corpus Christi, Tx
    Craigslist find here locally. The tie rod end is broken on left front tire and a rear end control arm is broken but other than that it still drives. ;). Maybe i should just leave it alone then and just do the install if its safe to say itll run to 200k miles. Ill never put that on her anyway.
  3. nobreaks254
    nobreaks254 Veteran Member
    495
    9
    Jul 14, 2007
    aberdeen, SD
    the only issues ive seen with these motors is the cam bearings. They were bad in almost every ls motor Ive taken apart. Darn good deal for 1000.
  4. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    Wifes '99 Camaro SS has 208k on it, only did knock sensors and the mod to the
    steam vent crossover tube (fore/aft). Sure it rattles at startup, but what LSx
    engine doesnt? My '04 GTO has 125k on it. That said, I have an LT1 Impala SS
    with 230k and I traded out my '93 Z28 LT1 Camaro with 265k on it, just did the
    valve seals on that one. They last a long time, I wouldnt touch it, save that $$
    for all the stuff you will find you need after diving into the swap.;)
    Tom
  5. arick793
    arick793 Veteran Member
    1,127
    Oct 27, 2008
    Rochester, NY
    I believe one of the header collectors is angled toward the outside of the car. Guys have been heating up the primary tubes and bending them back to straight. You could sell the T56 for enought money to just about finish the swap. It'll bolt right up to the t-350 with either an adapter for the torque converter, or a special torque converter
  6. 1970camaroRS
    1970camaroRS Veteran Member
    2,606
    Mar 4, 2001
    Everett, WA
    Yup, there's a thread on here or ls1tech about that.
  7. spav350
    601
    Apr 8, 2009
    Corpus Christi, Tx
    I'm doing a cam swap for sure, so those will come out. I may try and find an LS6 cam and intake to put in it. I'd like and aggressive lumpy cam, but I don't know if I want my car to rattle apart either.
  8. spav350
    601
    Apr 8, 2009
    Corpus Christi, Tx
    I'll check that out.
  9. JJFarmer
    JJFarmer Veteran Member
    2,447
    Jun 28, 2002
    Lenoir City, TN
    I put a 220/220 duration with .555 lift @ 114 CL in mine before I did the swap. I like the sound and performance out of it. I wanted a 224 dur @ 112 CL.
    This is mine
    Check out cam clips of different cams on youtube
  10. speed_m5
    speed_m5 Veteran Member
    1,075
    13
    Apr 17, 2010
    Baytown Texas
    I am doing the swap now in my 72. I went with the kwik performance brackets the f-body alt bracket kit my pitman arm and i did not want to notch my subframe for the AC I am using vintage air also. I bought the dynateck headers also Around 450.
