$1000 '70 LS1/T56 swap
Discussion in 'High Tech Retrofits' started by spav350, Feb 25, 2012.
  1. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
    My install of the Spectra tank in a later 2nd gen is now in the Sticky above.
    Tom
  2. spav350
    spav350 Veteran Member Lifetime Gold Member
    601
    Apr 8, 2009
    Corpus Christi, Tx
    So what are you thoughts on that tank and pump set up? Any issues like others have had, regarding loss of power when cornering or when level is below 1/2 full?
  3. newschool72
    newschool72 Veteran Member
    1,185
    Feb 25, 2011
    forsyth,ga
    Im running the FAST EZ EFI on my 72 with the external pump, and although i havent had any issues,YET, I think Im going to weld a CE sump to my stock tank with a baffle to help the system work better.
    If I am thinking right , I should be able to use the factory pick-up for my return line. That would move the return surge far enough away from the sump area.
    i will have to most likely build a bracket for the fuel pump to get it low enough, but short of a dedicated EFI tank, I think thats a good way to eliminate fuel starvation. I figure I can do the whole project for 100.00, but my brother in law is a welder. Figure another 60 bucks or so if you have to farm that out.;)
  4. JJFarmer
    JJFarmer Veteran Member
    2,447
    Jun 28, 2002
    Lenoir City, TN
    I made a small baffle to go in my 76 tank and used the in tank pump. I have had zero trouble with mine and have ran mine down very low on fuel. Unless your doing your best drifting moves, I don't think you would have any issues.
    I used the Corvette regulator/filter assembly and my return dumps in on the pump base thru the old tank pick-up line.
  5. JJFarmer
    2,447
    Jun 28, 2002
    Lenoir City, TN
    Yes, get rid it it.
  6. spav350
    601
    Apr 8, 2009
    Corpus Christi, Tx
    Just unplug and remove everything related to emmisions and reprogram the ECM? Is that it?
  7. camarochevy1970
    camarochevy1970 Veteran Member
    7,815
    62
    Jan 23, 2003
    Pittsburgh, PA
    Pretty much
    Only thing you really need are the front o2 sensors, but the rear sensors, the egr etc can all be removed and turned off in the computer via a tun
  8. spav350
    601
    Apr 8, 2009
    Corpus Christi, Tx
    sweet!
  9. camarochevy1970
    7,815
    62
    Jan 23, 2003
    Pittsburgh, PA
    That's for emissions mind you, for the remainder of the engine, you need the map sensor, knock sensors, cam sensors etc.
    Just didn't want ya not hooking anything up and trying to run it ;)
  10. spav350
    601
    Apr 8, 2009
    Corpus Christi, Tx
    I knew all those had to be hooked up.. I was asking about the EGR and other related B.S.
