17x8 with 4.5 BS all around
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by 1974blackz28, Apr 8, 2019.
  1. 1974blackz28
    1974blackz28 Veteran Member
    108
    Jan 29, 2010
    Detroit
    Has anyone run 17x8 wheels with a 4.5 backspacing on all four corners?
    If so pictures? I just came across a local ad for the exact wheels I want with this setup but 1/3 the cost.
    Would appreciate any input!
  2. 1974blackz28
    108
    Jan 29, 2010
    Detroit
    Anyone?
  3. 8pack
    2,504
    101
    Aug 29, 2007
    Pittsburgh, PA
    Stock are 15x7 with 4.5" BS. You should be fine with an 8" wheel, there is plenty of room in the wheel wells for the extra wheel width.
  4. badazz81z28
    15,760
    279
    Las Vegas, NV
    This site has had a lot of the same questions answered 10x over in the last 20 years. Try a search if you can’t get the answers you need quick. There is actually a fitment guide as a sticky in this forum.
  5. 1974blackz28
    108
    Jan 29, 2010
    Detroit
    Totally agree.. I am much more or a lurker than a question asker. If I actually post its only after I've searched this forum and others online. I was unable to find a clear answer on whether they would work on the rear... Everyone said they would work on the front so I was unsure
  6. Jeep43
    Jeep43 Veteran Member
    1,167
    29
    Mar 30, 1999
    Connecticut
    Steel 15x7 Z-28 wheels and 15x7 N90's have 4.25" BS so with a 4.5" BS on an 8" wide rim you are pushing the wheel lip out .25 and the inside wheel lip in .75. 4.5" BS is a very common BS for aftermarket 8" wide wheels but when you add some wide rubber and lower the car you can get rub near where the fender well bolts to the fender arch. There is more room in further to tolerate more than 4.5" BS but the wheel selection drops.
    I went for 4.75" BS and they fit close but no rub yet.
