195cc vs 210cc
Discussion in 'Engine Topic' started by earnhardtgm3, Nov 27, 2011.
  1. earnhardtgm3
    earnhardtgm3 Veteran Member
    2,723
    34
    Dec 18, 2007
    Camaro Country,GA
    Looking at getting another set of aluminum heads for my motor.Looking at the AFR's now, but don't know which are better for my needs.Motor is:
    350 bored .030 over
    Flat top pistons
    Voodoo 103 camshaft
    High Performance street cam likes 2400 RPM stall, 700 cfm carb, dual plane intake and headers. Makes un-equaled power to 6200 RPM with proper valve springs. If you're looking for a Very Strong cam with great street manners then this cam is it.
    Advertised Duration (Int/Exh): 268/276
    Duration @ .050 (Int/Exh): 227/233
    Gross Valve Lift (Int/Exh): .489/.504
    LSA/ICL: 110/106
    Valve Lash (Int/Exh): Hyd/Hyd
    RPM Range: 1800-6200
    Holley 300-36 dual plane intake
    Jegs headers
    3:42 posi Turbo 350 with 2700 stall converter
    Holley 770 street avenger carb
    Which head would fit my motor needs better?And what cc's would you use.I was looking at the 65cc for optimum quench.Give me you input.
  2. mildthing
    mildthing Veteran Member
    217
    Nov 17, 2011
    Benson, Utah
    180s for your 350. 195s for a 383, 210s for a 406-408
  3. Philip
    Philip Veteran Member Lifetime Gold Member
    1,807
    May 30, 2006
    Marana, AZ
    I am running that same cam in a 406 with AFR 195 heads with 65cc chambers. My block has been decked and with dished pistons my compression is 10.7:1 static. The engine pulls hard, is fun to drive and gets decent gas mileage.
  4. Led Zep
    Led Zep Veteran Member
    542
    11
    Mar 13, 2008
    Ky
    The 195 Eliminators were designed to be run on the 2 most popular SBC engines- 355/383.
  5. mildthing
    217
    Nov 17, 2011
    Benson, Utah
    You don't need 195s on a 350 when they'll feed a 400 to 525 HP and 6500 RPM on a HR 236/242-110 cam. You're not spinning your 350 fast enough to benefit from huge 195s.
  6. Rene Melten
    Rene Melten Veteran Member Lifetime Gold Member
    4,020
    Sep 22, 2007
    Blind Bay, B.C.
    My 350 .060" over with approx. 9.7 compression has the AFR 195 65cc Street Eliminators. (Need to change gasket to improve quench thou.) B/W ST-10. Sorry no time slips but I did have to get a rev limiter too keep it under control. The parts I selected were for up to 6500 rpm. I wouldn't recommend this cam for an automatic it only gets 8" to 9" vacuum at idle.
    Cam Specs Hyd.
    int. 240* ex 246* @.050"
    int. .507 ex. .510 total lift
    LSA 110
    RPM AIR GAP
    Holley 750 HP
    670 Street Avenger works too
  7. Todd80Z28
    11,323
    148
    Jun 11, 2002
    Northern VA
    AFR 195s have a solid rep.
  8. Led Zep
    542
    11
    Mar 13, 2008
    Ky
    Call Tony Mamo.1500 bucks for a set of heads,he will steer you in the right direction.
  9. Philip
    1,807
    May 30, 2006
    Marana, AZ
    Spoke with him before ordering mine.
    Rene what is your quench? I have mine at .049". Had to deck the block to get it there, no one makes a thin gasket for a 400 sb.
  10. Rene Melten
    4,020
    Sep 22, 2007
    Blind Bay, B.C.
    Yeah I messed up here, lack of knowledge at the time. Afr has a gasket that matches the Felpro 1094 and my supplier couldn't get the AFR gasket so they sold me the Felpro 1034. I need the .015" thick gasket to get that optimal quench. I'm sitting at .066 or something stupid like that. .025+.041"=.066:mad:
