1968 Chevrolet Camaro SS 396 4 speed
Discussion in 'Camaros for Sale' started by Scott Powell, May 18, 2019.
  1. Scott Powell
    Scott Powell New Member
    Jan 1, 2018
    Kirkland, Washington
    1968 Camaro 396 325 HP SS Muncie 4 speed and factory 3:31 posi 12 bolt rear end
    See Video Walk Around on YouTube
    Wild About Cars Garage Channel https://youtu.be/Gfn6v2iiOFc
    · 100% correct Numbers matching car Frame Off Restoration recently completed
    · 69,150 Original miles before restoration - Odometer is now reading 70,670 –
    Less than 1,000 since complete frame off restoration!
    The only modification on the car is the upgrade to the Factory correct OEM Power Front Disc Brakes
    A complete Front Disc Brake OEM Factory correct setup was added at a cost of $2,500
    All factory OEM Drum brake parts (Also in 100% Restored condition) come with the car
    VIN# 124378N323905
    Vehicle Identification Breakdown
    · First digit: GM line number, Chevrolet = 1
    · Second digit: Series number: Camaro = 2
    · Third digit is engine code: 3 = 6-cylinder, 4 = V8
    · Fourth & fifth digit: Body Type Number: 37 = Sport Coupe (1967-69) 67 = Convertible (1967-69) 87 = Sport Coupe (1970-71)
    · Sixth digit is model year: 8 = 1968
    · Seventh digit is N for Norwood assembly, L for Van Nuys
    · *Last six digits increased one with each car built at each plant
    Trim Badge
    * 10A --> 10(build month) A(First week)
    * 68-12437 --> the two digit year ("67," "68," or "69") was followed by a five-digit "ST" body style code, e.g. 12437. The first two digits of the style code are the model code ("12") and the last two digits are body code ("37" for coupe and "67" convertible).
    * 712 --> Interior black, bucket seats
    * NOR --> Norwood manufacturing facility
    * 23480 --> body build number (sequential), typically a few off the VIN build # (23905)
    * - - double dashes typically represented special paint request and could be Tuxedo black which was deleted in Jan 68
    Engine Code T1003MW 18N323905
    * T --> engine assembly plant Tonawanda
    * 1003 --> engine build date Oct 3rd
    * MW --> 1968, Camaro, 396CID/325HP, L-35, Manual transmission
    * 18N323905 --> Numbers that relate to VIN, if the same then a number matching car. 1 is Chevy, 8 is 1968, N is Norwood; and the remaining numbers are the production seq of the vehicle VIN
    Transmission Code tymdds P8R21 Muncie M2x 4 speed, Oct 21, 1967
    * t --> transmission type --> 4 speed Muncie
    * y --> model year not calendar year --> 68
    * m --> month --> October
    * dd --> day of the month --> 21
    * s --> suffix, may or may not be used
    1967-1969 Camaro Manual Transmission Castings
    Transmission - Muncie 4-speed
    Case Info - material: aluminum 7-bolt side cover
    1968-1969 - 3925660
    Concourse quality restoration on a number matching 396/325 Super Sport Camaro. This car is documented back to the original owner! New owner receives the original title.
    This "blue chip" investment has all original drivetrain and is a complete #s matching car
    Factory 396 engine, 4-speed transmission and 3:31 posi 12 bolt rear end.
    Other Factory options include
    · smog equipment
    · 15" chrome rally wheels, (Original set of Goodyear Polyglass GT F-60-15 tires come with the car)
    · It now wears a proper period correct set of BF Goodrich Radial T/As for drivability
    · Original spare and jack
    · OEM front & rear spoilers
    · As equipped from the factory proper black vinyl to
    · Factory center console cluster tic-tok-tach, 120 mph speedometer
    · Hurst shifter, console w/gauge package
    · AM radio
    SOLD AS IS WHERE IS BUYER RESPONSIBLE FOR SHIPPING
    Price: $63,500.00
    Call Scott: 425-633-0601
    s-l1610.jpg s-l1601.jpg s-l1604.jpg s-l1609.jpg s-l1608.jpg s-l1603.jpg s-l500.jpg s-l1605.jpg s-l1606.jpg s-l1602.jpg
    Dave Nelson likes this.
  2. stafs05
    345
    17
    Dec 26, 2007
    chicago,IL
    Very nice Camaro. Good luck with your sale.
  3. Scott Powell
    Jan 1, 2018
    Thank you very much. She is a beauty. Please let anyone know who might be interested. I even have the original licensing from Indiana.
    Regards, Scott
  4. Kae450
    Kae450 Member
    40
    10
    Feb 5, 2018
    I just went out and bought a lottery ticket. My god that car is nice.
  5. Scott Powell
    Jan 1, 2018
    Thank you very much Kae450! The odds on this lotto ticket are much better:)
