1970 - 1981 Camaro Windshield Eyebrows.
Discussion in 'Fbody Warehouse' started by MuscleCarBolts, Jan 12, 2016.
  1. MuscleCarBolts
    MuscleCarBolts Member NastyZ28 Sponsor NazstyZ28 Sponsor Lifetime Gold Member
    87
    Jan 30, 2014
    Buffalo NY
  2. joselk1
    joselk1 Veteran Member
    226
    12
    Jul 24, 2014
    Waterford, MI
    I have set of these but I still don't know where exactly they go....
  3. Coadster32
    1,624
    130
    Oct 2, 2013
    Milford,CT
    I have them...just don't know the proper way to install them.
  4. BillyDean7173
    BillyDean7173 Veteran Member
    1,502
    280
    May 21, 2014
    Hutto, TX
  5. MuscleCarBolts
    87
    Jan 30, 2014
    Buffalo NY
    I smell a install video coming!
    They install pretty easy. the 2 wing tips on the end tuck under the front side A pillar window trim.
    They lay on top of the cowl panel and wrap across under the front fender tips and you will see a bare hole in the cowl panel about 6 inches across from the A pillar post and slightly down by the fender tip. That is where the mounting point is for the small bolt that holds them in place. They wrap the lower curve of the front windshield at the bottom corners.
    Hope this helps I can knock out a short video also need to get the MuscleCarBoltKits YouTube page started I suppose!
    hubedobeedo likes this.
  6. 70 SS/L78
    2,726
    102
    May 5, 2005
    Rockford, MN
    These windshield eyebrows will fit a 1970 model but they're physically different than originals.
  7. iaz28
    iaz28 Member Lifetime Gold Member
    95
    May 1, 2010
    high plains
    eyebrows
    I believe that the 1970 eyebrows are a one year only item,
    the 71,72 and 73 part#9868729 LH and 9868728 RH are different from the
    74 forward part#3062232 LH and 3062231 RH
  8. CamarosRus
    CamarosRus Veteran Member
    8,483
    139
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    Scott, In your opinion would it be better to have these NEW repops on a show quality 70 than used scratched up originals........
    Is the cosmetic difference significant ????
  9. CamaroMan79
    CamaroMan79 Veteran Member Lifetime Gold Member
    5,204
    10
    Jun 10, 2001
    Selah, WA
    Did these come on the 78-81's?
  10. TommyRS70
    TommyRS70 Veteran Member
    1,158
    94
    Jan 31, 2004
    KY
    Not only are non-1970 a different design, the mounting holes are in a different location as well. If all goes as planned, look for 1970 GM factory style reproductions this summer. They will be dead-on identical to the originals but without the GM numbers, of course.
