1970 Camaro engine frame mounts
Discussion in 'Engine Topic' started by Jbullok, Aug 31, 2017.
  1. Jbullok
    Jbullok New Member
    8
    Aug 9, 2016
    Tulsa
    Help, I have a 1970 Camaro that had big block engine and frame mounts. I am trying to locate frame mounts for a SBC for a 70 camaro. I can find most anything that fits a 1st gen Camaro and some early 70's nova's such as this from Jegs. But it does not list as compatible for a 1970 Camaro.
    OER 3955184
    Frame Mount 1967-72 Small Block ChevyOER
    Question, will a first gen frame mount work for an early 2nd gen. Any help is appreciated.
  2. l16pilot
    1,821
    133
    Dec 13, 2004
    Hurlock, MD, USA
    Simple answer is no...1sts Gen frame mounts will not fit/function on a 2nd Gen. However, if you already have the 70-71 big block mounts, purchase the engine-side motor mounts for a 70 Z28 and you should be good to go. The 70 Z28 and 70 SS396 used the same frame-side mounts.
  3. Jerry Stanton
    Jerry Stanton New Member
    Jun 27, 2012
    Anoka, MN
    Does anyone know where you can purchase frame mounts for a 72 Camaro with SBC Engine?? I purchased a Roller with No Engine and No Tranny. I have an Engine and Engine Mounts, but the Frame Mounts were gone, and I have not been able to find anything...
  4. gary bickel
    gary bickel Veteran Member Lifetime Gold Member
    443
    13
    Nov 4, 2013
    fort worth tex
    I ha
    I have some SBC mounts for 70 camaro I will give you you pay shipping. Im in Texas. Gary
  5. bourbon_scotch
    2,356
    122
    Jan 10, 2003
    USA
  6. Desert_Dick72SS
    Desert_Dick72SS Veteran Member
    197
    Feb 10, 2009
    San Francisco Bay Area
  7. Jerry Stanton
    Jun 27, 2012
    Anoka, MN
    Thaks for the Offer Gary, but I already Purchased New Ones...
  8. Jerry Stanton
    Jun 27, 2012
    Anoka, MN
  9. Jerry Stanton
    Jun 27, 2012
    Anoka, MN
  10. Rich Schmidt
    Rich Schmidt Veteran Member
    4,278
    38
    Mar 27, 2010
    Denville NJ
    I think the trans crossmember is different too. The big block and Z-mounts move the engine to the side. The only automatic cross member is for a TH-400. If you use the regular small block mounts and the TH400 crossmember from a big block/Z I think you might braak the trans casing. All TH350 and powerglide crossmembers are for regular small block mounts.
