1970 Camaro Z28 RS (Looking to Purchase)
Discussion in 'Camaros Wanted' started by B Rod, Oct 16, 2019.
  1. B Rod
    B Rod New Member
    12
    Apr 15, 2018
    Hello!!
    Looking to Purchase 1970 Camaro Z28 RS 4 Speed. Prefer numbers matching car with documentation. Understand these cars are not cheap and willing to pay the price for the right car. Not looking to steal a car or low ball ya. Looking for someone ready to sell there toy...
    Let me know what you have... Sorry Not looking for any projects either.
    Thanks,
  2. B Rod
    B Rod New Member
    12
    Apr 15, 2018
  3. 70lt1z28
    3,418
    681
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Don't know that particular car, but I question a few of the numbers based on what I have seen in the past.
  4. 70-camaro
    70-camaro Veteran Member
    2,389
    440
    Mar 25, 2010
    marietta ohio
    I don't believe the stripes on the hood are correct . It should also have hideaway wipers with the RS package.
    Dean70Z28 likes this.
  5. servello2005
    servello2005 Veteran Member
    191
    24
    Jun 22, 2013
    toronto ontario
    i noticed the Z has a few things wrong under the under hood that are expensive for $70k should be correct.
  6. 70lt1z28
    3,418
    681
    Oct 3, 1999
    Wheels are also wrong year...and what's up with the lug nut?:eek:
    70-camaro likes this.
  7. roeville
    roeville Veteran Member
    1,247
    87
    Oct 9, 2000
    SF East Bay CA
    This is usually an indication that someone installed an RS front end on a non-RS car.
    Like a reproduction air cleaner.
    Good catch on the wheels Dave! 1970 one-year-only wheels are getting hard to find and are the most expensive Z wheels.
  8. Vettenick
    Vettenick Vettenick
    97
    18
    Jul 17, 2019
    What's wrong with the wheels?
  9. 70lt1z28
    3,418
    681
    Oct 3, 1999
    The hole where the valve stem goes through is only 5/8 inch wide oval on early 70 wheels up to an early June build. Then they were about 13/16 wide through 74. When the Z28 reappeared in 77 it had a 1 inch round hole.
    Thinking more about the build date on this car it actually may be ok to have the 13/16 wide slot.
  10. 70lt1z28
    3,418
    681
    Oct 3, 1999
    I may have jumped the gun on the wheels (see post above), but you are correct there are numerous details under the hood that are not correct. Some would say nit-picking, but for 70K I would expect it to be correct.
    Example: The smog pump should not have a relief valve on the pump body. That ended in 1968.
    The master cylinder is incorrect.
    The distributor photo is fuzzy, but the stamps look suspicious to me.
    Some things potentially more serious, but I'm not an expert like some so I won't comment on those.
