1970 Heater Core
Discussion in '1970 - 1973 Specific' started by gpm6367, Sep 11, 2019.
  1. gpm6367
    906
    46
    Feb 12, 2005
    New Joisey
    Are they all created equally?
    I ordered one off of eBay and the photo showed it to be brass (or copper?) and when it got here it was actually silver and the welds did not look that good so I sent it back. May have been aluminum?
    Is the brass/copper preferred? Any issue with going to my local Napa?
  2. Twisted_Metal
    26,895
    909
    I replaced my original with a new copper/brass one 15 years ago.
    It lasted 13 years before an antifreeze dribble appeared on the passenger floor. :(
    I asked the same question about heater cores two years ago...
    Mine has an aluminum radiator and intake so everything the antifreeze contacts is either aluminum or iron (block, heads pump).
    I figure there's less chance for galvanic reaction/corrosion by NOT adding copper to the mix of metals.
    So... I've got a new aluminum heater core waiting to be installed.
    (It's been gathering dust in my garage for 2 years. :screwup: )
    gpm6367 likes this.
  3. gpm6367
    906
    46
    Feb 12, 2005
    New Joisey
    And I sent the aluminum one back. :)
  4. 70lt1z28
    70lt1z28 Veteran Member
    3,254
    634
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I had my original recored but it cost a ton. When I think about it, I’m not sure I will ever drive the car when it’s cold enough to need a heater. I may just plug off the hoses.
    gpm6367 likes this.
  5. gpm6367
    906
    46
    Feb 12, 2005
    New Joisey
    My radiator is not aluminum so I think I’ll get an original brass/copper style.
    Most of them on eBay are aluminum. There are some that are significantly more expensive and I’m trying to find out if they are brass/copper. Is there even an advantage to spending the extra money for brass/copper?
  6. gpm6367
    906
    46
    Feb 12, 2005
    New Joisey
    Would ANYONE recommend using either of the existing original heater cores that I have? They weren’t leaking when removed but are almost 50 years old. I don’t want to ever have to pull this apart again...
  7. xten
    xten Veteran Member
    2,726
    1,494
    Sep 24, 2014
    Pittsburgh, Pa.
    I would get them pressure tested. That would be a good starting point. The one I sent you did not leak. I thought I remember you saying there's a rad shop near by.
    gpm6367 and BillyDean7173 like this.
  8. Twisted_Metal
    26,895
    909
    I pressure tested my new one. (Don't want to do the job TWICE!)
    I hooked it up to the hoses and let it sit on a towel on the fender well until the coolant got hot and up to normal pressure.
    No leaks... I called it good.
    gpm6367 likes this.
  9. 70lt1z28
    3,254
    634
    Oct 3, 1999
    Easy to check with a compressor and set the regulator to 15psi (I went to 25 on mine) and dunk it is a tub of water and look for bubbles.
    gpm6367 likes this.
  10. BillyDean7173
    BillyDean7173 Veteran Member
    1,472
    272
    May 21, 2014
    Hutto, TX
    Just FYI, the original Harrison heater cores (at least the early ones) will be stamped with a date code. I can't remember if it's stamped "Harrison" like the radiator.
    I found out about the date code when I pulled what I thought was an original heater core (it was brass/copper) out of an original heater box I picked up years ago and shipped it to the guy who was restoring my original 73Z radiator. When the old timer got it, he said what the hell is this? Then I got schooled, LOL. For one, the aftermarket had a sticker on it with the date code.
    Knowing then what to look for, I pulled the real deal core out of another heater box I had and then got schooled on how he pressure tests the cores. It checked out good and I didn't have to have him re-core it.
