1970 LA Z28 COPO?
Discussion in 'Original Drivetrain Topic' started by mgd1790, Sep 15, 2018.
  1. mgd1790
    mgd1790 Veteran Member
    943
    23
    Nov 25, 2003
    Suburban Chicago
    Just arrived...505425 sequence, 02A/02B. Lots of parts in boxes, including hopefully the trim tag. Rusty, obviously. Looks like original lacquer, tight stripes for LA cars, floor-mounted pedal, suspension stopper thingies, etc. Black and white stripes look original. I'm looking for the build sheet(s).
    Please let me know your thoughts.
  2. 70lt1z28
    2,796
    431
    Oct 3, 1999
    Beavercreek, Ohio, USA
    An 02B is much earlier than the currently accepted entry time for the COPO 9796 which is late April of 1970.
    All of the early (prior to April or March?) LA cars that I have seen have been “short stripe” cars where the stripes did not extend all the way to the windshield in front and the rear glass in back. This car looks like it has full stripes which indicates a repaint. The tall rear spoiler may have been added at that time. It was pretty common to add the tall spoiler in the mid 70’ and 80’s to modernize the look of the short spoiler cars.
    Other than that, somebody has their work cut out for them bringing this one back.
  3. mgd1790
    943
    23
    Nov 25, 2003
    Suburban Chicago
    My 71 LA car had full stripes and the paint was untouched in the rear.
  4. ronzz572
    1,923
    51
    Feb 8, 2007
    imperial pa
    Mike the build sheet in most cases on a 70 vannuys built Camaro are on the drivers side edge middle of gas tank, Also under drivers seat bottom, My 02C L78 had one inside the passenger back seat cover. If you do find one make sure it matches the cars vin. Sometimes there have been other build sheets found from different cars. Vannuys plant build sheets are often somewhere in the car.
  5. mgd1790
    943
    23
    Nov 25, 2003
    Suburban Chicago
    Here's some more pictures. No build sheet yet. Taking down the headliner in a few. Sheet metal in the trunk was toast and sifting through the rust I did find a couple scraps but I'm not sure if that was the build sheet.
  6. 70lt1z28
    2,796
    431
    Oct 3, 1999
    By 71 the stripes were full length. Only early LA 70 cars were short striped. Even then, the hood went full stripe before the back did.
  7. mgd1790
    943
    23
    Nov 25, 2003
    Suburban Chicago
    Makes sense. While cleaning out the interior it looks like it was originally a green mist car, repainted black. Time to focus on the spoiler I suppose.
  8. secondgenaddict
    secondgenaddict Veteran Member
    305
    89
    Dec 29, 2012
    Upstate South Carolina
    The 2 sets of holes on the edges of the decklid indicate that the spoiler was changed out at some point...
    jbloake likes this.
  9. mgd1790
    943
    23
    Nov 25, 2003
    Suburban Chicago
    Makes sense. So I understand, the small spoiler which is standard and I've had on my 71, had 2 holes on the left and right side and because they swapped out this one at some point, 2 other holes to fit the tall spoiler were drilled, correct?
  10. 70 SS/L78
    2,610
    69
    May 5, 2005
    Rockford, MN
    Yes.
    Like Dave said in post #2, February is way to early for a copo spoiler car.
    Also black would of been special order paint, so cowl tag would have -- for the paint code.
