1970 Power Steering Reservoir Cap
Discussion in 'Original Drivetrain Topic' started by bkmont, May 27, 2018.
  1. bkmont
    bkmont Veteran Member
    1,151
    76
    Nov 14, 2010
    Pensacola, Florida
    Can anybody share a picture of the correct powering steering cap for a 1970 Z28?
    Thanks,
    Bryan
  2. jbloake
    jbloake Veteran Member
    350
    85
    May 1, 2002
    Atlantic Canada
  3. 70lt1z28
    3,491
    695
    Oct 3, 1999
    Beavercreek, Ohio, USA
    As far as I can tell, it is a 70 only "9 bump". Also used on Chevelles and probably others in 70. This is a "transition" cap from the earlier metal style used on 69 and earlier and the 18 bump style on 71 and laters. The 18 bump style came in at least two versions that had different text on the top.
    These come up once in awhile on eBay. I paid 30 for mine. I saw a couple at a swap meet this weekend but they were on pumps and they didn't want to separate them. If I would have brought an 18 bump I think they would have.
    An often overlooked part. Once you see this, it is interesting that many concours level cars have the wrong cap.
  4. bkmont
    1,151
    76
    Nov 14, 2010
    Pensacola, Florida
    Thanks! Just wondering. I came across one in my shop that has the 9 bumps but i think the wording is a little different.
    How about the below picture? What did this come off of? It is 9 bump cap
  5. 74BIBELOT
    74BIBELOT Veteran Member
    865
    53
    Jan 19, 2006
    El Paso Tx, Cd Juarez Mx. Las Cruces NM.
    FE4F052F-757D-4C2F-AABF-4127A022EF04.jpeg B5DD926C-4730-44C6-9650-12E03B81FF0B.jpeg B1F0E007-6B94-4C02-A713-DE0E4D2955C3.png 7CA0F3FA-CF7C-4555-BB16-13BA1B856412.png 3CDE7072-13BB-48EB-A95E-694B26449CFF.png BE28BDE1-1DED-4BAC-BBD8-60C9B1F15C61.png Not to much help and if correct for a 70 Z , but a find a pic of a 9 bumps cap with different wording.
    I have two pumps with 9 bumps caps, not sure about wording(need to check)
    My 74 original pump has the 18 bumps cap with the same wording as bkmont cap.
    Regards
  6. 70lt1z28
    3,491
    695
    Oct 3, 1999
    Go figure. About the time I think I know something. The "Do not overfill" seems to start in the 75 to 77 time frame. I had never seen a 9 bump version of that. I have not seen any 70 9 bumps with it.
  7. 70-camaro
    70-camaro Veteran Member
    2,430
    488
    Mar 25, 2010
    marietta ohio
    B60A1871-1D60-49BD-B1FC-07A4A3E943FA.jpeg My 9 bump 70 but not a Z28.
  8. Ote
    Ote Member
    79
    11
    Sep 24, 2017
    Kennewick, WA
    Here is a pic of the cap on my 71 Z28. It's the cap that came with the car in 1971. 9 bump with Do Not Overfill wording.
  9. 70lt1z28
    3,491
    695
    Oct 3, 1999
    I need to increase my sample set! Its hard to tell as this gets changed out so easily and the replacement pumps more than likely come with 18 bump version. At least we have some solid definition now.
  10. Dave Nelson
    Dave Nelson Veteran Member
    4,480
    2,441
    Dec 19, 2003
    Vineland N.J USA
