1970 Rear body panel trunk drop off bracket research
Discussion in 'Original Drivetrain Topic' started by ronzz572, Jun 23, 2019.
  1. 70lt1z28
    3,017
    532
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Norwood 04B trunk dropoffs 2 drains.
    These are originals to the car.
    jbloake likes this.
  2. x77-69z28
    x77-69z28 Veteran Member
    303
    13
    Feb 5, 2010
    long island, new york
    My 04D van Nuys Z has 2 holes in each drop off
  3. ronzz572
    1,944
    61
    Feb 8, 2007
    imperial pa
    My 02C and my 03C vannuys cars have both holes. My 03C Norwood car has 1 hole. But I restored it and dont remember if it started out with 2 holes originally. Would love to know the answer on it. Also looking for the the early trunk drop brackets for my 03C L78 Camaro. They are missing. That's what started my investigation on the trunk drop brackets. Anyone have a donor car they can remove them from?
  4. bkmont
    bkmont Veteran Member
    1,112
    62
    Nov 14, 2010
    Pensacola, Florida
    My 06C Norwood has 1 drain hole in the drop offs and a single piece tail panel bracket.
  5. giggity
    giggity Veteran Member
    846
    64
    Mar 18, 2013
    Pearland, texas
    Ill have to look for the drain plugs too, but heres my bracket...I dont believe its 2 piece, but ill look
  6. 70lt1z28
    3,017
    532
    Oct 3, 1999
    What is your build date?
    always nice to have the build date in your sig.
  7. giggity
    846
    64
    Mar 18, 2013
    Pearland, texas
    ok, dug up build sheet. Its a Van Nuys, where is date on build sheet? I see Schedule No Date as 3-31
  8. 70lt1z28
    3,017
    532
    Oct 3, 1999
    Mos times when we refer to build date it is of the form "Month Week" on the Trim Tag, where the number of the month (04 for April) and a letter for the week (A= the first week and so on). Mine is 04B for April and the second week.
    See here:
    http://www.nastyz28.com/decode.html#trimtag
    Note that this is not the exact day your car was built, but rather when Fisher Body started the process of the body build. Things could delay the final build completion (example is a strike or ) but usually is completed in a day or so.
    Some things like when the trunk drop offs went from 2 holes to one we will most likely never know the exact date and there could very well be legit cars with a one hole on one side and a two hole on the other (a transition car) but with the TT build date info we can narrow it down to maybe a week or so with enough info.
  9. giggity
    846
    64
    Mar 18, 2013
    Pearland, texas
    ok, so Mine is 03E, so March, 5th week?
  10. 70lt1z28
    3,017
    532
    Oct 3, 1999
    Yes
