1970 RS SS rear filler panel
Discussion in 'Body Restoration' started by KT 70 RS SS, Aug 15, 2019 at 8:34 PM.
  1. KT 70 RS SS
    KT 70 RS SS New Member
    16
    Mar 28, 2019
    I have a 1970 Camaro that need the rear filler panel replace. I purchased one that was cut out of another car. Not sure if I should try and use it or buy a new one. But it looks like adding the hinges may be more work that I may not be able to do. Any suggestions..
  2. hubedobeedo
    hubedobeedo 3rd times a charm
    382
    120
    Jul 18, 2013
    Huntertown,IN
    looks like solid piece ,that is not a quick job to do and will require careful removal as not to create extra work. i would not buy aftermarket.you have enough material to use .take the decklid off and remove all the seam sealer where the piece meets the 1/4 panels and use a spotweld removal bit to drill the spotwelds. where they cut the panel at the front you will save trimming that for last.the area that is cut to match in the channel will be where you will make sure and align evenly because it is a butt weld. also underneath the part you will have other bracketry to deal with.take your time if in doubt stop and ask
    bodymanbill likes this.
  3. hubedobeedo
    382
    120
    Jul 18, 2013
    Huntertown,IN
    i see you have a trunk drop off panel in the pic,hows the 1/4's if that is something getting replaced(the 1/4's) you might do the hinge along with them.
  4. bodymanbill
    bodymanbill Veteran Member
    1,170
    523
    Feb 1, 2007
    South Park Pa
    Also make sure u test fit the decklid with the weather strip and the filler panel installed before welding anything.
    hubedobeedo likes this.
  5. KT 70 RS SS
    16
    Mar 28, 2019
    Should I only cut and piece where its needed. The original hinges and metal around them are still good.
  6. KT 70 RS SS
    16
    Mar 28, 2019
    The 1/4 panels are both solid. They were replaced years ago and held up. The trunk drop panel on the passenger side is all that needs to be replaced.
  7. KT 70 RS SS
    16
    Mar 28, 2019
    I will post pics of all the spots cleaned up before I start doing any cutting and post them for more consulting. Thanks to both responses and great advise.
  8. bodymanbill
    1,170
    523
    Feb 1, 2007
    South Park Pa
    image.jpg image.jpg Here's a couple pics of mine when removed, yours will be a little easier since its a used panel and already has the trunk hinges and trunk support brackets on it.
  9. KT 70 RS SS
    16
    Mar 28, 2019
    I dont have a complete panel. He cut just above the hinge tension bars. Thats why I was considering cutting below the hinges that are still good on original panel Your thoughts..
  10. bodymanbill
    1,170
    523
    Feb 1, 2007
    South Park Pa
    Dam I just noticed its cut to short on the front, that su&ks. Might have to go with a new one and transfer over all the stuff just because he was probably 2 inches short. U could section it up there if yours is good but id probably just get a new one.
