1970 RS SS ?
Discussion in '1970 - 1973 Specific' started by ozziecam, Feb 7, 2017.
  1. ozziecam
    ozziecam New Member
    Aug 8, 2016
    Adelaide South Australia
    I am going to have a look at a so called "RS SS" this weekend. I am only a newby when it comes to Camaros (will be my first) so looking for a bit of help.
    What should I be looking for to determine it is a RS SS 350.
    I understand the engine suffix, rear sway bar and hide away wipers are a few to look out for, what else is easy to spot?
    Did every car have a build sheet attached or was it pot luck?
  2. Gary S
    20,806
    223
    SS 350 would have a Muncie 4 speed if manual tranny or TH350 if automatic. The TH350 doesn't identify an SS as it was available on any Sport Coupe as well. It would also have a 12 bolt rear end. The rear swaybar was optional on SS350, so that doesn't help.
    Build sheets were common on Van Nuys build cars, but rare on Norwood cars so you likely will not find one.
    ozziecam likes this.
  3. ozziecam
    ozziecam New Member
    Aug 8, 2016
    Car has a Muncie, the 12 bolt and its a Norwood build.
    Would the Hurst T style shifter be the original?
  4. Budz
    2,891
    27
    Mar 17, 2002
    Ashburn, Va USA
    If you mean T Handle, no it's not original. There are different variations of them.
  5. Gary S
    20,806
    223
    Check the VIN on the Muncie. If it matches the car, it would have to be either a SS or Z28. SS would have a 3.31 12 bolt. Check the ratio. If that matches, it is an SS. The Z28 12 bolt were either 3.73 or 4.10. SS396/350 would also have a 3.31 rear and SS396/375 would have either a 3.55 or 4.10 12 bolt.
  6. Green hornet
    Green hornet Veteran Member
    1,027
    134
    Oct 11, 2015
    North Bay, CA
    Good luck with your inspection and keep us posted on how it turns out.
  7. ozziecam
    ozziecam New Member
    Aug 8, 2016
    This is the shifter, yes i know it is the wrong steering wheel.
    Thanks for everyones help.
  8. ozziecam
    ozziecam New Member
    Aug 8, 2016
    Some more photos taken by a mate, I am yet to see the car in person. Have checked the trim tag and vin tag, thanks to this site for the coding. IMG_2777.JPG IMG_2789.JPG (2).jpeg IMG_2790.JPG IMG_2767.JPG IMG_2768.JPG
  9. hogg
    hogg Veteran Member
    3,126
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    I belive there is something about the red line on the tec. some one may know,low back seats
