1970 SS grill emblem ?
Discussion in 'Body Restoration' started by 67johnny, Jan 5, 2018.
  1. 67johnny
    67johnny Veteran Member
    154
    Apr 14, 2016
    vancouver
    Hey all.
    Just got my replacement grill and have sold my original that needed repair.
    Cant locate the detail info and I have seen them done two ways.
    Can someone set me straight as to the correct placement?
    Thanks!
  2. l16pilot
    1,782
    98
    Dec 13, 2004
    Hurlock, MD, USA
    ....this. Might be the angle, but he emblem appears upside down.
  3. steins70z28
    steins70z28 Veteran Member
    216
    31
    Apr 14, 2012
    Tulsa, OK
  4. 67johnny
    154
    Apr 14, 2016
    vancouver
    Looking at the back side of this SS emblem you can see a locator slot. I thought it was on the top side of the horizontal bar. The manual seems to show the two pins going through the horizontal grill on the bottom side 4 rectangles showing. emblem rear veiw.jpg
    Here is a better pic of where I thought it should end up.
    Would have been easier to tell on the car with the bumper in place.
  5. 70 SS/L78
    2,632
    73
    May 5, 2005
    Rockford, MN
    That looks about right but it's a lot easier to tell when the bumper is on. The emblem is NOT centered like you would think. It's actually down 1 slot, closer to the bumper.
    Not the best pic but this should help
  6. hogg
    hogg Veteran Member
    3,165
    27
    Dec 29, 2000
    pegram,tn.,cheatam
    ? I thought the ss grils were painted silver,on outer edge?
  7. 70 SS/L78
    2,632
    73
    May 5, 2005
    Rockford, MN
    NO, it's actually a chrome metal trim piece that goes around the outside edge. It's made of pot metal like other trim pieces so they would get corrosion pits pretty easily.
  8. l16pilot
    1,782
    98
    Dec 13, 2004
    Hurlock, MD, USA
    Scott - I think he means the plastic edges of the grille itself.
    Hogg - only the RS gilles were black with silver/argent edges...and all RS grilles were this way including SS and Z28. The full-bumper grille was all argent unless SS or Z28, in which case it was all black. All full-bumper grilles had the chrome potmetal surround as noted by Scott. The photos of his grille is spot-on.
  9. Rugratman
    Rugratman New Member
    27
    Oct 25, 2018
    Mine will not tighten down. It has about an inch of play.
    Maybe I have the wrong thickness of Grille? Is that possible?
  10. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    1,102
    25
    Jan 1, 2005
    Schererville,In.46375
    Could be wrong SS emblem...
