1970 unibody stamping
Discussion in '1970 - 1973 Specific' started by rs/ssmike, Aug 2, 2018.
  1. rs/ssmike
    rs/ssmike New Member
    26
    Jan 20, 2018
    Sonora, CA
    IMG_1950.JPG Anyone know what this means? stamped on the floorpan on the front passenger seat. Looks like K5 7584, with the K backwards.
  2. 70 SS/L78
    2,590
    64
    May 5, 2005
    Rockford, MN
    Most likely a date code and partial part number.
  3. 2ndGenCrazy
    2ndGenCrazy Veteran Member
    677
    24
    Aug 18, 2011
    Upstate New York
    Hamilton Stamping Plant 5th week of 1970. The other number may be a partial part number.
    That plant was located near Norwood.
    I'm assuming all the Camaro sheet metal was shipped to the L.A. assembly plant from there as well.
    Your body date code on the cowl tag should be near after the 5th week of the year. Maybe late Feb. or early March.
  4. 2ndGenCrazy
    677
    24
    Aug 18, 2011
    Upstate New York
    If that is a "K", I know I saw that plant discussed here on this site. I can't remember what it was however.
  5. rs/ssmike
    26
    Jan 20, 2018
    Sonora, CA
    IMG_1964.JPG IMG_1961.JPG Thanks for the info. I will search for the discussion about the plant. It sure looks like a backwards "K" to me. The car was built in LA on March 11.
  6. rs/ssmike
    26
    Jan 20, 2018
    Sonora, CA
    Or maybe its just a messed up "H"
  7. rs/ssmike
    26
    Jan 20, 2018
    Sonora, CA
    stamp on the package tray starts "T 05". So it sounds like the process was: Unibody panels were stamped at various stamping plants and then brought together at a unibody assembly plant. So I could end up finding panels from several different plants as I strip the unibody?
  8. 2ndGenCrazy
    677
    24
    Aug 18, 2011
    Upstate New York
    I thought I had identified the "T" plant at one time. Of course, I can't recall it now, but it was on the North side of Detroit. I have found H,K and T on my 1970.
  9. 2ndGenCrazy
    677
    24
    Aug 18, 2011
    Upstate New York
    Ternstedt This is the only plant with a "T" that I could find.
  10. 2ndGenCrazy
    677
    24
    Aug 18, 2011
    Upstate New York
    djorgensen3 likes this.
