1970 Z28 carburetor replacement
Discussion in '1970 - 1973 Specific' started by Juan Nicholls, Mar 28, 2019.
  1. Juan Nicholls
    Juan Nicholls New Member
    Mar 28, 2019
    What holley carburetor can replace the holley 4555 today?
  2. ronzz572
    1,929
    52
    Feb 8, 2007
    imperial pa
    I would look at the 3310 series 750 holley or the replacement 4555 carbs.
  3. COPO
    17,231
    474
    Toronto, Ontario, Canada
    The 750 with vac sec Holley burns better than the stock 780. I know cause I have both carbs and have run them on my 70 Z28.
    Juan Nicholls likes this.
  4. 70lt1z28
    2,911
    472
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I really liked the 4779 Holley double pumper I had on mine. Much better response than the vacuum secondary carb.
  5. FlaJunkie
    6,243
    181
    Mar 24, 2001
    Rockledge, Florida
    Really? I always liked the way the 780 ran. It was easy to overhaul and setup. And it had vac secondary.
    Why did you think the 750 is better?
  6. COPO
    17,231
    474
    780 is over carbureted. I always had gray tailpipes with the 750!but not with the 780.
  7. FlaJunkie
    6,243
    181
    Mar 24, 2001
    Rockledge, Florida
    Sounds like it wasn't jetted properly for the location. Airflow should not be the color driver here.
