1970 Z28 deck lid emblem location
Discussion in '1970 - 1973 Specific' started by Jeff L - 1970 Camaro Z28, Nov 14, 2017.
  1. Jeff L - 1970 Camaro Z28
    Jeff L - 1970 Camaro Z28 New Member
    10
    Nov 14, 2017
    Need help locating the holes in my new aftermarket deck lid to mount the 'Camaro by Chevrolet' emblem. Does anyone have the dimensions?
  2. l16pilot
    1,782
    98
    Dec 13, 2004
    Hurlock, MD, USA
    Jeff - I have a virgin decklid with the factory emblem holes. I can make a template this evening and advise if no one else chimes in before then.
  3. l16pilot
    1,782
    98
    Dec 13, 2004
    Hurlock, MD, USA
    Hope this helps. First shows placement on the deck lid.
    This shows dimensions.
    70 SS/L78, FlaJunkie and flowjoe like this.
  4. Jeff L - 1970 Camaro Z28
    10
    Nov 14, 2017
    wow. I'm very impressed with the detail. thank you very much and i'll let you know how it works out.
  5. l16pilot
    1,782
    98
    Dec 13, 2004
    Hurlock, MD, USA
    Jeff - Hope it works out well for you and welcome to the forum. Also, those are factory holes. If you are planning to use the OER-brand emblem, the studs will not line up with the factory holes, but the emblem produced by Trim Parts does. Just an fyi.
    TommyRS70 likes this.
  6. flowjoe
    7,957
    24
    Feb 7, 2006
    SoCal
    Trim Parts pieces are soooo much nicer than OER...even nicer than OEM usually:D
  7. 70 SS/L78
    2,629
    72
    May 5, 2005
    Rockford, MN
    On non-Z28's there are 2 locations, depending if you have a spoiler or not. No spoiler sits lower on deck lid, with spoiler it moves up. Since Z28 comes with a spoiler it will use the upper location as shown above.
    For hole location all you have to do is look at the underside of the deck lid. The inner steel layer on trunk lid has an access hole for a socket to attach the nut, which pretty much tells you where it has to go. Only the center hole is used to bolt on the emblem, the other 2 holes are for keeping the emblem aligned. If I recall there is 1 access hole for each of the two locations.
  8. FlaJunkie
    6,247
    181
    Mar 24, 2001
    Rockledge, Florida
    Is there any special sealant used on the three holes?
  9. badazz81z28
    16,031
    345
    Las Vegas, NV
    I used windshield ribbon. The Butyl stuff around the holes to seal them
  10. Tony P
    Tony P New Member
    Jun 14, 2019
    I tried printing the sheet that you would tape on the trunk lid for the hole layout but when printed it was not straight, can you help??
    Tony
