1970 Z28 deck lid emblem location
Discussion in '1970 - 1973 Specific' started by Jeff L - 1970 Camaro Z28, Nov 14, 2017.
  1. Smokin'Joe
    Smokin'Joe Veteran Member Lifetime Gold Member
    726
    58
    Aug 14, 2008
    Texas
    I don't think printing it out would work anyways, as it would be more difficult to scale it inch for inch. - I think sketching it out on a blank sheet using the measurements l16 provided should get you what you need.
  2. Tony P
    Tony P New Member
    27
    Jun 14, 2019
    I will have to covert to inches, thanks!!
  3. l16pilot
    1,845
    138
    Dec 13, 2004
    Hurlock, MD, USA
    Sorry Tony...it was easier to get more accurate measurements in millimeters. Take the millimeters x.03937 to get inches.
  4. TommyRS70
    TommyRS70 Veteran Member
    1,186
    97
    Jan 31, 2004
    KY
    If you use the centimeter side of the ruler, you will be happier with the results. Clear flexible rulers are handy for this
    Ps...L16, love your engineering drawing style!
  5. Tony P
    Tony P New Member
    27
    Jun 14, 2019
    Thanks!!
  6. Tony P
    Tony P New Member
    27
    Jun 14, 2019
    With the spoiler on how would I place the template on the trunk lid?
    Tony
  7. flht99b
    flht99b Veteran Member
    268
    44
    Nov 28, 2014
    Knoxville, TN
    Is the Camaro emblem location in the same place on 71 Z28's ?
  8. COPO
    17,867
    753
    The 70 emblem was a 70 only and dropped sometime in June. The 71-73 was a different emblem with the red rectangle around the letter C. In 71-73 it was deleted if you ordered a rear spoiler.
  9. l16pilot
    1,845
    138
    Dec 13, 2004
    Hurlock, MD, USA
    Not sure how to help you there Tony. You could remove the spoiler...or just drill the center mounting stud hole from the inside out centering the hole in the access hole in the bottom trunk structure. then, use that hole to with the template to locate the other two holes.
  10. flht99b
    268
    44
    Nov 28, 2014
    Knoxville, TN
    Thanks.
