1970 Z28 engine questions
Discussion in 'Original Drivetrain Topic' started by gpm6367, Jul 13, 2019.
  1. gpm6367
    917
    52
    Feb 12, 2005
    New Joisey
    Mastic what? You apply after install or it’s applied to box and then box to the wall?
  2. gpm6367
    917
    52
    Feb 12, 2005
    New Joisey
  3. COPO
    17,919
    775
    I would use 3M Dumb dumb in strips from Napa to reseal the box.
    gpm6367 likes this.
  4. 70lt1z28
    3,439
    682
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Here is some stuff you use on the inside kick panel covers to seal them to the body:
    https://www.homedepot.com/p/Gardner...t-Seal-Compound-DS-110/100212441#.UTtjwFdgk1k
    You can use it for this also, but it won't look original.
    For most original look, there's this:
    https://www.grainger.com/product/3M-Seam-Sealer-2KUU3?opr=APPD&pbi=2KUU3&analytics=altItems
    followed by a stiff brush to get the lines
    This might be as good and a bit cheaper:
    https://www.amazon.com/SEM-40477-Wh...t=&hvlocphy=9003540&hvtargid=pla-801158443172
    gpm6367 likes this.
  5. gpm6367
    917
    52
    Feb 12, 2005
    New Joisey
    Both sides or just firewall side?
    What connects the hard plastic diffuser vents together? Flex hose? Anyone have pics? Underhood or out of car?
  6. 70lt1z28
    3,439
    682
    Oct 3, 1999
    Huh?
    you mean the underdash stuff?
    gpm6367 likes this.
  7. gpm6367
    917
    52
    Feb 12, 2005
    New Joisey
    Yes there is hard black Plastic diffusers at each dash vent and the defrost. Something must attach to those hard plastic diffusers from the heater box under dash.
    flex hose of some type?
    What’s it look like and is it sold?
  8. gpm6367
    917
    52
    Feb 12, 2005
    New Joisey
    B8B9233E-C951-469B-9FA8-CFB472AC566E.png Totally confused. This is the tape that goes between heater box and firewall? White?
  9. gpm6367
    917
    52
    Feb 12, 2005
    New Joisey
    01691BDD-903C-48EA-9DDF-7F7994886373.jpeg 9F22E14D-B8C3-49C2-897F-32C180A3DCD3.jpeg What type of nut holds the heater box to the firewall? Captured washers?
  10. gpm6367
    917
    52
    Feb 12, 2005
    New Joisey
    I have the 2 cables for the heater control with a tie that holds them someplace under the dash. Not sure which goes where. Which end goes where. Each cable bolts to the controller?
    Anyone have any pictures or AIM diagram?
