Ok so it appears I’m missing the electric switch that the fan arm feeds into. The fan arm is intact as is the box to secure the switch to the controller. Does anyone have any parts controllers that I could pirate that electrical switch from?
You have done a lot of work getting the car back to its original configuration. Looks like you're on the home stretch now. Hats off to you! Bryan
Finally got back out to shop with all parts waiting for me. The duct work was a pain in the ass, as had been most of this job. The defroster duct is definitely meant to be installed before the dash. The pin on the drivers side took me an hour before I could figure out how to rig up something to install that retention washer. But the interior is back together, full size glove box and all! Unfortunately the opening for controller was trimmed...is that part of lower dash? You can see how the ducts were modified for the VA flex hoses. I do need the light plug for the heater controller. Anyone have a picture of what it looks looks? Just need to change out fitting in water pump to 3/4 and reinstall heater hose.
