1970 Z28 engine questions
Discussion in 'Original Drivetrain Topic' started by gpm6367, Jul 13, 2019.
  1. gpm6367
    914
    49
    Feb 12, 2005
    New Joisey
    Yes I am referring to the harness dropping down out of that channel in inner fender well. It won’t stay up higher and apparently I'm not missing a tie down.
    Someone mentioned heating mine up and forming it so if stays up is s possibility. Make use a hanger wire hidden and taped to harness while it settles in.
    When I add the underhood light wire it gets two ties and I also see I’m missing tape in 2 spots. I’ll then try to heat and mold it to the inner fender well.
  2. gpm6367
    914
    49
    Feb 12, 2005
    New Joisey
    Why do I seem to have one less harness on drivers side than both pictures above? I have one wrapped harness and the wiper hose. The pictures above have 2 wrapped harness and the wiper hose and underhood light wire? AIM shows one. Wtf?
  3. COPO
    17,867
    753
    WTF is right. My other harness I wrapped is all my MSD wires from the 6AL 6420. There should only be 1 plus the washer hose. Both pics are the same car, mine.
    gpm6367 likes this.
  4. gpm6367
    914
    49
    Feb 12, 2005
    New Joisey
    Whew! Thought I was missing a harness!
    Ok thx.
    So plan is to reinstall underhood light with ties, run the washer hose properly, heat harness and add tape in 2 places with a hidden hanger wire to maintain proper placement on the inner fender well.
  5. gpm6367
    914
    49
    Feb 12, 2005
    New Joisey
    Original bolt securing that ground strap? What size bolt head is that? Captured star washer?
  6. COPO
    17,867
    753
    3/8 socket
    gpm6367 likes this.
  7. gpm6367
    914
    49
    Feb 12, 2005
    New Joisey
    85CE64E7-7768-4180-90E1-B4ACFD370C5D.jpeg 6D8A7B3E-55C5-4353-9E1E-FD41D24321C8.jpeg F84FDFBD-C466-45F1-915D-AB601192C69B.jpeg I am getting ready to reinstall the heating system in the car and took a look at blower motor area. While I originally thought there was a plate fabricated it looks like the VA system came with a circular block off plate that is used with a half lb of tar like dum dum to seal opening.
    I am not familiar with this area of firewall. Is the blower motor area as depicted all original? All I need to do is bolt up heater box and blower motor bolts up to box?
    Isn’t there a VIN stamped somewhere around here?
  8. COPO
    17,867
    753
    Could be on the bottom side or even on the top.
    gpm6367 likes this.
  9. gpm6367
    914
    49
    Feb 12, 2005
    New Joisey
  10. 70lt1z28
    3,417
    681
    Oct 3, 1999
    Beavercreek, Ohio, USA
    No gasket. Mastic smeared around the edge
    gpm6367 likes this.
