1970 Z28 Fender Emblem Location
Discussion in 'Body Restoration' started by TEDDYS CAMARO, May 25, 2007.
  1. Ken70
    Ken70 Member
    30
    Jul 14, 2018
    Long Island NY
    Gary
    Im looking for the 70 script Camaro fender template? Do you have info you can share?
    Thanks
    ken
  2. badazz81z28
    17,340
    596
    Alabama
    The assembly manual has placement dimensions.
  3. Ken70
    Ken70 Member
    30
    Jul 14, 2018
    Long Island NY
    Thank you
  4. 70lt1z28
    3,518
    711
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I know this is old but looking a the fenders in particular it would be a challenge, but not impossible, to make a punch and die setup for a manual punch op at the assembly plants. The punch needs a die side to fit flat against the back side of the panel and with the inner fender-wheel well flange on one side and the internal bracing on the door side it would be difficult to articulate a die in place. Much easier tooling-wise to just have a light weight drill bushing type fixture that locates on the outside to a few key locations and then hand drill the holes. Also, FWIW, I checked the holes on my fenders and there was no evidence of a pierced hole. No die roll or break from a pierce punch. There are interesting methods for die-less piercing of holes, but these are rather exotic using electromagnets to accelerate the pierce punch. Picture shooting a bullet hole in a piece of sheet metal, but the bullet is very sharp and travelling much faster than a bullet. Probably didn't even exist in 1970.
  5. BillyDean7173
    BillyDean7173 Veteran Member
    1,791
    437
    May 21, 2014
    Hutto, TX
    Agreed. I'm going to go with you, twozs, and others on this thread: not punched.
