1970 Z28 Motor Question
Discussion in '1970 - 1973 Specific' started by Tubbys57, Oct 4, 2013.
  1. Gary S
    22,657
    835
    Unless you can find a build sheet, it is almost impossible to document the RS package. It isn't coded into any of the permanent car parts. But, if it has all the RS trim parts, you can pretty safely assume it came as an RS.
  2. FlaJunkie
    6,273
    185
    Mar 24, 2001
    Rockledge, Florida
    The VIN should have an "L" in it.
    I find the motor build date a bit questionable; there is over a month from engine build until the car was built.
    It is probably nothing.
  3. Tubbys57
    Tubbys57 New Member
    18
    Oct 4, 2013
    Blue Grass State
    Yes I thought it looked a little long also?? And yes there is an L in vin,,,
    Next the last question What's it Worth???
    Numbers match eng, trans 4 spd, 12 bolt
    Z28, RS
    Body above average southern car, needs paint and lower front fender/door work
    Interior very good no holes
    Under hood driver but has air cleaner and aluminum valve covers
    Motor and trans rebuilt... With paper work
    I know this is hard with out seeing the car but what I like about the car is the numbers matching...
    Thanks
  4. al8apex
    al8apex Veteran Member
    3,917
    Mar 11, 2005
    scottsdale, az
    5k - 25k
    how much do they want?
  5. Tubbys57
    Tubbys57 New Member
    18
    Oct 4, 2013
    Blue Grass State
    They are asking 21K my gut says its worth 18K??
    $18K + $6K Paint + ? Engine Detailing = $24K+
    What's it worth complete with documents??
  6. Tubbys57
    Tubbys57 New Member
    18
    Oct 4, 2013
    Blue Grass State
    Sorry I mean what is it worth restored without docs??
    Thanks,
  7. ls777z
    ls777z Veteran Member
    2,170
    23
    Feb 19, 2000
    Clay,NY
    If the body is solid (providing there are no surprises under the paint) and no documentation for the RS package I would say the $18,000 is probably close to it. Sort of depends on what else you've looked at, what they looked like and how much they were asking. Matching numbers will guarantee your investment can only go up. :)
  8. 1970camaronut
    1970camaronut Veteran Member
    125
    Jul 25, 2010
