1970 Z28 Who Sells - rear stabilizer support bushings
Discussion in 'Original Drivetrain Topic' started by COPO, May 25, 2010.
  1. COPO
    15,499
    92
    Toronto
    I'd like to replace my rear stabilizer support rubber bushings part # 3983072. GM no longer carries them. Before I check the source if any from the local suspension garage here in town, I wondered what others are using.
  2. Dave Nelson
    2,816
    140
    Dec 19, 2003
    Vineland N.J USA
    Mark, I have also checked many sources with no luck.
  3. 70 SS/L78
    No one that I know of sells them and originals are hard to come by..... I've come across NOS bushings only a couple of times and they sold for around $150!!
  4. FlaJunkie
    5,527
    17
    Mar 24, 2001
    Rockledge, Florida
    I've been asking that question for a while. Does anybody know if they come in the neoprene kits?
    I was thinking if I can't find one, maybe I could split a piece of heater hose to substitute.
  5. CamarosRus
    CamarosRus Veteran Member
    This is one of those items that NOBODY has found a "correct looking"
    replacement for.
    Too bad somebody with experience cant source out vendor who can extrude these parts.......
  6. COPO
    15,499
    92
    Toronto
    Ok, then what could I use rubber wise to wrap more in there to snug the connection up. 1 side moves a bit side to side where my finger is pointing.
  7. Dave Nelson
    2,816
    140
    Dec 19, 2003
    Vineland N.J USA
    Mark , carefully remove the old bushing , and wrap the area where the bushing was on the bar with rubber electrical tape (not plastic). May take a couple times for just the right thickness.
  8. INSPECTOR57
    INSPECTOR57 Veteran Member Lifetime Gold Member
  9. 70 SS/L78
    Like David said above^^..... If you decide to build it up, I would recommend 3M Scotch 23 electrical rubber splicing tape. It's a vulcanizing rubber so it bonds to it's self without using an adhesive. The adhesive on normal electrical tape gets slimy when it gets hot..... Another option would be cloth electrical tape.:)
  10. COPO
    15,499
    92
    Toronto
