1971 camaro hidden vin
Discussion in 'Camaro Questions' started by Travel3r, Sep 29, 2019.
  1. Travel3r
    Travel3r New Member
    10
    Aug 19, 2018
    Hi
    On 1971 camaro the hidden vin located by heater box is it full vin or partial? Also is there any other hidden vin on the car?
    And the numbers on front passenger side inner frame it's the date, month, year, plant and shift is stamped correct?
    Thank you
  2. x77-69z28
    x77-69z28 Veteran Member
    330
    28
    Feb 5, 2010
    long island, new york
    It’s a partial. Will start with a 1 for 71, then either an N or L depending on plant, then sequential. My 70 Van Nuys Z also has one below the heater box.
  3. 70 SS/L78
    2,725
    102
    May 5, 2005
    Rockford, MN
    Like Buddy mentioned above, stamp on firewall behind heater box is just a partial VIN but those numbers should match your VIN on dash. No other hidden VIN's.
    Stamp on front sub-frame is a date code. nothing to do with VIN but it should predate the cowl tag.
  4. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,016
    149
    Dec 19, 2008
    VIN SWAP LOL. Both replies correct.:)
  5. 71RSLS
    71RSLS Veteran Member
    754
    162
    Dec 5, 2017
    Prairie City, Ia
    Maybe not.... I've had 3 of these cars where the firewall was gone in the heater box area due to rust issues. This hidden vin is good to know where it is so you can determine if a car has been VIN changed though.
