1971 Z28 - Numbers Matching Advice
Discussion in '1970 - 1973 Specific' started by newtodu06, Nov 18, 2019.
  1. secondgenaddict
    secondgenaddict Veteran Member
    342
    134
    Dec 29, 2012
    Upstate South Carolina
    Find another head that is close the date of the correctly dated head... no big deal. I prefer to put aftermarket rods, ARP rod bolts main studs along with custom SOLID ROLLER CAMS or hydraulic roller cams in everything I build just to ensure longevity.
    If you run a flat tappet you really should run specific flat tappet HIGH ZINC - AMSOIL or the like to ensure you give it a chance to survive... along with AMSOIL OR LIKE BREAK IN OILS, which have something like 1000 times more zinc than other breakin oils.
  2. Zoomin
    Zoomin Veteran Member
    102
    24
    Aug 5, 1999
    Oklahoma City, OK USA
    The time to define "numbers matching" is before you buy the car, not after. In general parlance, numbers matching refers to the block, numbers matching drivetrain means block, trans and diff and from there you better specify in detail.
    Personally I don't care what's inside - those could all be "born with" in a replacement block and that doesn't quite cut it.
    Sorry for your bad luck, but it'll only get better from here.
  3. badazz81z28
    17,432
    612
    Alabama
    Numbers #s matching to me means the born with Engine, Transmission and Rear end are with the car (Stamped with the VIN). Totally different than a "all original" car. I can guarantee MOST of your restored cars out there do not have the original internal engine components, the valves in the head, seals, seat coverings, carpet... etc..etc..The engine, trans, diff are surely rebuilt on any quality restoration. That engine is probably .030 overbore too. A car that's rebuilt and ALL correct with all period GM parts is a tough feat and a very expensive one. Not worth to most. I'm surprised he even gave you money for the cam replacement. You own a car when you drive off with it as bad as that sounds. I don't think anyone deceived you...Even if you inspected the car personally, you probably wouldn't have even asked and he may not have even known. People look at date code on the big parts.
  4. BillyDean7173
    BillyDean7173 Veteran Member
    1,843
    456
    May 21, 2014
    Hutto, TX
    It's my understanding that as far as rear ends, there is no VIN. On my 73Z, there's a date code on the lower RH side next to the differential cover and an axle code on top of the RH axle tube maybe 4" from the differential.
    I can't recall if there's any other numbers like a part number on the differential and axle tubes.
