1972 Accelerator linkage.
Discussion in '1970 - 1973 Specific' started by Rugratman, Dec 6, 2018 at 9:23 AM.
  1. Rugratman
    Rugratman New Member
    8
    Oct 25, 2018
    Going to a Holley. My previous bracket is not even close.
    I Have a Edelbrock Air Gap and a Holley Carb.
    The cable I have now is square end. I see them on sites, with a round end.
    Guessing I need to change that too.
    Any other parts or is there a " Complete" kit out there I should be looking at?
  2. CorkyE
    9,715
    298
    You do have an accelerator cable, not the old rod type? You shouldn't have to change anything on the cable, just get a bracket that works on a Holley. If you have an automatic transmission, make sure the bracket has that fitting also. Jegs, Summit, and others have a huge variety available from cheap stamped metal to machined aluminum.
  3. Rugratman
    8
    Oct 25, 2018
    Yes, just a cable. However it has a square end. All the brackets I see are a round end.
    Thanks Corke
