1972 Camaro Door Lock Cylinder/ Short or Long Cylinder ??
Discussion in 'Interior Restoration' started by MyFirst72Camaro, Mar 8, 2017.
  1. MyFirst72Camaro
    MyFirst72Camaro New Member
    Feb 17, 2017
    Ok so here's the deal. I own a 1972 Camaro building it from scratch and I am currently on the door lock cylinder replacment phase of my build. I need help in what components I exaclty need to replace my door lock cylinders on both passenger and driver side. Also are they short or long cylinders for 1972 and what other components go behind the lock cylinder other then the lock cylinder & the pawl?
    Any help would be appreciated!
  2. COPO
    18,059
    863
    MyFirst72Camaro likes this.
  3. COPO
    18,059
    863
    1972 part # is 1394244
    It doesn't say long or short.
  4. larrylarry
    larrylarry Veteran Member
    1,553
    72
    Dec 22, 2011
    San Antonio Tx
    Classic Industry's catalog has some info on which ones to use. I ordered a set for my 78 cause they needed to be keyed the same.
  5. MyFirst72Camaro
    Feb 17, 2017
    Here it is!! If you are looking for your Door Lock Cylinders this is the exact type that fit our make and models!!!
