1973 Camaro Restoration/Build- Bein Bad
Discussion in 'Project Progress' started by 7/3-SplitRS, May 5, 2017.
  1. thesalboy
    thesalboy Veteran Member
    352
    121
    Mar 25, 2017
    Los Angeles, CA
    Clever use of spare engine parts!
  2. 7/3-SplitRS
    7/3-SplitRS Veteran Member
    210
    26
    Mar 26, 2014
    Pecatonica IL
    Been awhile, but project has been moving along. I sourced a used door and front fender and then worked on getting panel alignment. All sheet metal is on the car and lined up. Just moved on to cutting roof off and rear quarter. Roof, rear quarter, in trunk drop off, tail pan etc will be being replaced. Roof is off and just started messing with the quarter. Used a grinder then borrowed a buddies plasma cutter. Love the plasma cutter! Will stay up to date with the build. Thanks for all the helpful hints! Everyone have a good memorial day. 20190523_205813.jpg 20190523_205802.jpg 20190523_205756.jpg 20190519_145716.jpg 20190519_144750.jpg
    moncam, Jas0n and dave@ztech like this.
  3. moncam
    moncam New Member
    8
    Jun 25, 2019
    Great build. Any update?
  4. Roberto Delon
    Roberto Delon New Member
    Dec 16, 2019
    I would like to know about the long bars --- probably going to make me feel stupid.
  5. Lars_2Gen
    Lars_2Gen Veteran Member
    625
    146
    Dec 29, 2017
    Fullerton, CA
    73 RS cars had one year only longer fender braces. These are not reproduced... if you find a 73 RS with shorter fender braces that match the 70-72 then they were either replaced due to an accident or more likely it's not a real RS.
    mrfleet12 likes this.
