1973 Camaro Z-28
Discussion in 'Project Progress' started by JCP_ProjectZ28, Mar 31, 2008.
  1. JCP_ProjectZ28
    JCP_ProjectZ28 New Member
    27
    Mar 31, 2008
    Longview, TX
    Here's the story. My two friends and I have always wanted to build an old Camaro, but none of us have ever done any body work or welding, cutting etc. Myself and one of the others do have some (very little ) knowledge of cars in general and engines etc. We do have access to a shop with all tools necessary for engine work, body work, and painting. This thing needs almost everything. Most body panels that have rust are getting cheap enough in the right places to straight up replace. It has no engine or transmission, it was a 4-speed car though. Has a crappy 10-bolt rear with 2.73 gears. Has most interior, but it all needs to be redone. We all know this is a big undertaking, and will be a great experience to do all this. My question is, which way would you go, old school drivetrain(crate engine, th400 or 4 speed, etc. ), which will cost out the ass on its own, or Find a pull out of an LS1 and t56 6 speed(which I've thought of putting behind an old school engine anyways?
  2. thedude327
    thedude327 Veteran Member
    778
    Feb 21, 2004
    Brighton,Michigan U.S.A.
    First off , welcome to the site. Now before you start thinking about drivetrains, it sounds like there is alot of bodywork to do. If your willing to try, you will learn plenty along the way. Old cars can test your patience. Be prepared for this project to take anywhere from a couple of years to much longer unless money and time aren't a problem. Good Luck and post back with questions or problems. There are many knowledgable folks here to help.
    Paul
    :bowtie:
  3. JCP_ProjectZ28
    27
    Mar 31, 2008
    Longview, TX
    yea, I know it's going to take a long time to do, and I guess I am getting ahead of myself, but the good thing about this project is that there are three people involved, which is three sources of income and three sources of time to work on it, so that is good. I'll be posting pics soon of the car as it is, and then some after we tear it down. Should all be by the end of this week. thanks for looking.
  4. 72BIGBLOCK
    72BIGBLOCK Veteran Member
    1,908
    33
    Feb 2, 2008
    SF
    so if 3 people are putting money in, who owns it?? welcome to the site
  5. JCP_ProjectZ28
    27
    Mar 31, 2008
    Longview, TX
    yea, i know it sounds crazy for three people to be putting money into one car, because people would think there would be trouble after it's complete, but these two guys are long long long time great friends that won't cause any trouble with, well I put the most money into it, or I have it titled in my name kinda thing. We're great friends and I'm confident it'll be that way, at least I hope...lol. sounds weird I'm sure, but you'd have to know us.
  6. 1st and goal
    1st and goal Veteran Member
    399
    Nov 5, 2005
    Seacoast, NH
    Good luck, as far as drivetrain goes, I went with an LS1 but it all depends on what you want to do with it.
    Drag car go old school, something to race a bit but enjoy on the street go modern. With the gas prices the way they are I'm glad I went with an LS1 vs the 502 I was mulling over before the swap.
    It was more expensive than I planned as I seemed to get a used motor with issues with some accessories (alternator, A/C compressor, injectors come to mind) so things will add up fast.
    Marc
    P.S. Get rid of the hood scoop :)
  7. JCP_ProjectZ28
    27
    Mar 31, 2008
    Longview, TX
    yea, that damn hood scoop is hideous, 3-4 inch cowl induction is what I would like to do.
  8. andrew1977
    andrew1977 Veteran Member
    1,501
    Oct 1, 2006
    parksvegas, BC
    dont under estimate the ten bolt rearend. if its stock it is a 8.5" ten bolt, and if built right, iv seen cars with 600+hp drag race with these rearends... seen pics of a car that runs 9s in the 1/4 with a built 8.5"
    most people confuse the 8.5" with the 8.2" because it looks very simaler. the 8.2" is garbage, but 2nd gen camaros were blessed with good rearends from the factory.
    BTW having a 273 geared rearend isnt bad either, in fact if you do have a posi your lucky... because if you had a 256 gear ratio (like mine had) you had to stick a ring gear spacer on the carrier to fit 273 gears and numeracly higher.. wich isnt as strong as the 273 and numeracly higher posi carrier because of the spacer.
    ^^^ bassically what im saying is there are two diffrent carriers gm came out with for 1970-1981 camaros. you have the good one, you can put like 410 gears if you wanted without having to use a ring gear spacer.
    (guessing its a posi)... its a great rearend.
    if it isnt a posi just buy an eaton posi with 30 spline axles, and c clip eliminators.... id be very suprised if you broke that with a street machine.
    i know my grammer and spelling is terrible.... im heading off to english class soon... maby i learn to spell
  9. JCP_ProjectZ28
    27
    Mar 31, 2008
    Longview, TX
    yea, i knew there were two different 10 bolts but I figured for some reason it would wind up being the weak one.
  10. JCP_ProjectZ28
    27
    Mar 31, 2008
    Longview, TX
    oh and no it's not a posi unit, but by this weekend I'll know if it's the good rear or bad as well....is there an easy way from the outside to figure out if it's the 8.2 or 8.5 rear end??
