1973 RS LT Z28 4spd Matching Nums
Discussion in 'Project Progress' started by secondgenaddict, Jan 5, 2013.
  1. secondgenaddict
    secondgenaddict Veteran Member
    341
    134
    Dec 29, 2012
    Upstate South Carolina
    Beautiful distributor-
    Same with the Smog pump, putting all new bearings inside -including the bonded bearing - you have to cut them out with a carbide or a diamond wheel - -- they are a PITA. Also picked up a REAL 458 pulley, the difference in weight is crazy compared to a REPRO...
    29295 diverter valve...
    ORIGINAL Master Cylinder sleeved by White Post. -
    I plated the lid and bale They sent everything back painted cast blast
    73rsltz likes this.
  2. 73rsltz
    73rsltz Veteran Member Lifetime Gold Member
    208
    53
    Aug 19, 2013
    taylors,sc
    Thanks Bro!! Looking great.
  3. 70lt1z28
    3,474
    690
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Those original '458 pulleys are great but cost a ton. Folks are wanting a grand for them now!
    The repops are very close especially when trued up. Pick your battles!;)
    Is the bale on the MC zinc plated? Thought they were natural unplated?
  4. secondgenaddict
    341
    134
    Dec 29, 2012
    The bale had plating on it, there were a few plated areas left, indicated by fizzing in a few small areas when dunked into muriatic acid solution.
    Pressed the bearings into place for the smog pump - rebuilt 3 at one time.
    Glued the front bearing into place after grinding a couple of rings around the outside.
    I filled the rings on the case with epoxy and then filled the grooves I cut into the bearings - then they pressed into place.
    FWIW -- To get the injected material out of the two grooves in the Smog Pump Case I used a 1" rotary wheel with 1/16 thick abrasive wheel which would get into the rings where the epoxy glue was injected (when you grind it, it smells like panel bond material)
    73rsltz and 70lt1z28 like this.
  5. secondgenaddict
    341
    134
    Dec 29, 2012
    It is against my religion to pay $1000 for a smog pulley... If you keep a keen eye out they can be found for 250-350. YOU HAVE TO BE ACTIVELY WATCHING AND IMMEDIATELY JUMP ON IT.
  6. secondgenaddict
    341
    134
    Dec 29, 2012
    Installed Joey's exhaust system... I have to say it looks super nice up under there, I did use some NOS offwhite exhaust donuts we had in our supply though.. ;)
    _MG_0716.JPG _MG_0738.JPG _MG_0710.JPG _MG_0724.JPG _MG_0745.JPG _MG_0730.JPG _MG_0721.JPG _MG_0740.JPG
    roadrace2, bodymanbill and 73rsltz like this.
  7. McCune
    McCune Veteran Member
    1,072
    191
    Aug 22, 2015
    st.george utah
    Bad ass James!
    73rsltz likes this.
  8. secondgenaddict
    341
    134
    Dec 29, 2012
    As my brother was warned... SMS is now the hold up...
    73rsltz likes this.
  9. 73rsltz
    208
    53
    Aug 19, 2013
    taylors,sc
    Thank bro looks great. Can’t wait to see it tomorrow. Yes SMS is almost two months over due....
  10. 74Z28GC3
    74Z28GC3 Veteran Member
    1,708
    50
    Sep 1, 2000
    North Pole, Alaska
    Your exhaust system and progress looks awesome. I purchased Joey Gray's exhaust system for my 74Z28 and will be installing it later this year. What ton are your jack stands? 12 ton?
